P1000 Lift HELP
Mays
31
34
Hey guys I'm new to the forum. Need some help. I just installed a Highlighter lift on my 1000-5 and now my rear shocks are hitting the tires! It's sitting on stocks right now while I wait on my new tires/wheels to come in. My question is will the new wheels be offset enough or will I need spacers. I have a big ride coming up and need this fixed ASAP.. Thanks guys.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Is your stock set up a "deluxe" (28x11x14 tires in the rear)?
what is the offset on your new wheels, and what is the new tire width?
you should be ok if your new tires are less than 11" wide...
69,261
First I've heard of this. I've got the same lift but with 10" wide tires all around. But I've only got a finger width between shock and tire. What psi is it. Have you ran it around so it didn't just come off the jack?
Mays
31
34
Mine is not the deluxe but it came with 27x11x12.. I ordered new 30x10x15 blackwater Evo on 15x7 hurricane wheels. There 5+2 offset. All I did was install the lift and the tire back on and let the jack down that's when I noticed it. You can even turn the tire if you wanted to.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
you'll probably be ok with the 5+2s and 10"wide tires.
Mays
31
34
Mays
31
34
I hope so! Have you ever heard anyone have this lift on stocks?
IMG 20170108 173248636 IMG 20170108 173248636
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
View attachment 30592 View attachment 30593
yeah, there's a few guys on here running the highlifter and stock deluxe wheels/tires (@CumminsPusher, @Delton ). I haven't seen them report any rubbing. the only caveat, is that they may have added wheel spacers, but not sure. one of those guys will chime in here in a few.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
but with 10" tires and 5+2 offset wheels, you should be fine with no spacer. I've run that same set up on mine (but with 3.5 offset wheels) with the highlifter and no rubbing.
Mays
31
34
10/4 thanks guy's I was freaking out for a minute there. New wheels/tires should be here tomorrow so we will see.
Reactions: CumminsPusher
69,261
You should be ok. Air the tires up and see if it helps I've got the stock non deluxe wheels.
Reactions: PioneerPete
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Are you sure you installed the rear lift correctlyo_O. Post some picso_O
Reactions: Plumber32
Eltobgi
Eltobgi
4,599
15,186
North Dakota
IMG 6194 IMG 6195
Here's a shot of mine stock rims and tires...plenty of clearance
Eltobgi
Eltobgi
4,599
15,186
North Dakota
IMG 6197 IMG 6198
Data on each. Below is the deluxe! Thought maybe offset could be different, but doesn't appear to be the issue!
Mays
31
34
Yea I did it right it was really easy going. I'll try to get some pics in the morning
Reactions: sharp
Bfree66
47
94
North Louisiana
I have the HL lift with delux wheels, but I have 1.5" spacers and I'm a long ways from the shock tower. I also have a set of 30 x 10 ITP Monster Mayhams wiith STI HD Beadlocks and a 5+2 offset and again no problems.
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
Mine ran perfect with the deluxe tires and wheels
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
With the tire size you are going with you may need a-arms. I have a set of 29.5x9.5x14 outlaw 2s on a set of 3+4 wheels and when turning they rub the inner fender.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Mine 3 lol. No problem with deluxe rims at all. It is close but no rub. I have 30-10-14 Evos on 5+2 10" rims. No problem running them. Wierd that you're having this problem.
