ehart814
Not be a Debbie downer here, but it sounds like you had someone put your tires on for you so the installing the beadlocks shouldn’t have been an issue. The leaking IMO is just people not taking there time installing them and not putting some thread lock on the bolts. If your not doing the above, your doing just what u said making sure u have the proper air in them and more maint. I do not have this issue with mine. Yes there a bit more in cost but with the cost of the LT tires and beadlocks I was still cheaper than regular wheels and UTV tires but close. Not busting your balls here, just sounded like u may have not understood the differences?
As for needing 90psi to set the bead. Hell yes you need that for most if not any LT tires for the reasons he told you. I’ve mounted many and even race tires need at least that. That said it doesn't necessarily mean that the bead will stay on better. It’s just the design of the tire to get the bead over the interior of the rim to seat the bead.When u ride, your worried about the cushion of the tire flattening the bead (from round to flat) to either pop it or leak air hence the reason why beadlocks keep you bead firmly on the wheel. You don’t have this bad with a good UTV tire cuz of the design but I’ve had them pop off without beadlocks.The outside of the wheel is more important than the inside in most Cases.
again, this is not a beadlocks is better than standard debate just showing u the difference.![]()
1. I don't want beadlocks, never felt the need. I don't rock crawl and run my tires with 2 psi. Also, looking back through this thread there are several people not running beadlocks. If I don't want/need them, I'm not willing to pay more for them. I paid 350 for my wheels (minus whatever I can get out of the worn BFG's that came on them) It would be at least $500 for a set of beadlocks. Yes, I understand the difference between beadlocks and regular wheels. I was trying to find out how low of a psi the other folks are running while NOT using beadlocks and if anyone had issues with the beads coming off (haven't heard of any yet).
2. I've mounted many sets of tires myself. Sometimes because it was my job, sometimes for myself. I've used tire machines, and hammers and spoons. This is the reason I had someone else do it - I don't like to. It was worth $50 to have someone else do it, and they included the balance beads for that money.
For those here that are NOT running beadlocks, have you ever knocked off a bead?
