P1000 Light Truck Tires
Russ989
Russ989
22,645
147,291
He either bought a cheap set, torqued or mounted them wrong. That said, I’ve never had a problem ;) When your installing them..patience is a virtue
Agreed! Those also have a pattern and torque spec, I’ll probably buy Beadlocks again for Trifecta but the thought of torquing all of those boots gives me mental pain. 🤕
Russ989
Russ989
22,645
147,291
I’ve thought about truck tires, still on the fence though. I really like these.
4E9A1FE0 B212 461E 9030 378D67F21EC1
jajohn00
83
156
US
That is a good looking tire. I have a stock set up so I don't think that I can use one that tall. But I did see them in a 235/75r15. Those are $133 for some reason.
Reactions: Russ989
ehart814
ehart814
1,701
3,889
NWPA
Reactions: jajohn00
116,574
Has anyone seen someone running the 31x11.50 super swamper ltb on a sxs?
Nope! But I bet there heavy as hell tho! That’s something you need to watch out for. You’ll dramatically lose your low end torque with to heavy a tire and wheel. I had supper swampers on a truck a long time ago and My back hurt bad taking them off Lol they were 33’s so not too far off what your looking at.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,535
15,490
Ohio
I want to say @Ohio4x4 is running super swampers- not that big if memory serves
I've got bias tsls in a 28-8.50-r14. They work great. I would still have them on if I hadn't gotten a great deal on some used regulators on method beadlocks. I put 2k miles on with no visible wear.
Reactions: dnjones161
ehart814
ehart814
1,701
3,889
NWPA
Bwaf covered everything pretty well.
I have put LT tires on 2 different machines. They have been awesome and I've never had a flat. You aren't going to wear them out any time soon. I know after 2000 miles on the first machine they still looked brand new.
For the riding you describe they will be a perfect fit. They ride a little stiff in really rough areas but outside of that they are excellent.
I recommend the 235/75-15
I have the maxxis buckshot mudder II now and I love them. (Grey machine) They get around extremely well. View attachment 109345View attachment 109346View attachment 109347View attachment 109348View attachment 109349View attachment 109350
I'm looking to get a set of these Maxxis tires. How do they do in mud? I'm hoping that they will steer the machine better than the factory bighorns. These heavy machines push so much when trying to turn in mud. I also have a hard time tracking in ruts - can't climb out of ruts in the mud and can't seem to stick well enough to straddle them (if that makes any sense at all). I think I will love how they go down the road, since I run a lot of road miles too. Have you put them through any abuse that could puncture them? If it wasn't for the stock 4 ply tires that I'm afraid I will puncture, I would not be looking to upgrade the tires until they wear out. Also, have you used them in deep snow?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I've ridden them in sharp rocks without an issue. They do well in mud and snow. They are a good all around tire that handles like a nice car on the road. I'd give them a 7 or 8 across the board. The one area they lack is on frozen or slick ground. They aren't soft enough to really bite when the ground is hard and slick. For that my berserkers do much better. They are a solid jack of all trades and great on the road.
ehart814
ehart814
1,701
3,889
NWPA
I waited for a couple months now for the berserkers to go on sale, but no luck. I'm kinda surprised that the maxxis don't bite great on hard and slick ground. I'd think the tread would bite hard on anything hard. But it makes sense, since these tires are designed to last 30k or more miles on a much heavier vehicle.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Yea I lucked out and got the berserkers on sale. I kept calling them until they finally gave in. They usually run sales on holidays.
The maxxis bite hard ground when its dry lol. This time of year when the ground is still froze but has a little mud on top they just dont hook up as well as berserkers. But yes they're made to go 30k or more on a pickup so it's a give and take. My goal is to put 10K miles on them and see how they look. With all the money on spend on this stuff I dont know why I care so much about tire life... principal I guess. Lol
I use the berserkers for trips and the maxxis the rest of the year.
212,853
30,000 miles? Ive got 3,000 on Rooster and on my 4th set of tires?
T
Tommy1214
6
Marshall tx
I know that they are lighter than the out n back max in a 32 by several lbs. Intercostal home page says 47 lbs per tire but if I shave a little to open the treads up I think I can stay around 50 lbs or a little less with tires and wheels.
T
Tommy1214
6
Marshall tx
That's cool I put 30 inch advantage vee rubbers on my 1000 last summer. We put maybe 1500 miles on them and I have worn half the tread off. Not too impressed with the mileage from them. From what I've heard truck tires should fix my problem
Reactions: Cuoutdoors
T
Tommy1214
6
Marshall tx
I know that they are lighter than the out n back max in a 32 by several lbs. Interco home page says 47 lbs per tire but if I shave a little to open the treads up I think I can stay around 50 lbs or a little less with tires and wheels.
ehart814
ehart814
1,701
3,889
NWPA
I got a set of these last night!
I also have a set of 31x10.5x15 BFG KO2 tires to sell, cuz they won't fit my machine
