P1000 Limited Edition - aftermarket axles
jjbartling
5
Iowa
Does anyone know a company that makes aftermarket cv shaft for the limited edition model? All I have found say exclude limited. I assume the shaft diameters are the same but the length must be different. Don't really want to shell out the money for OEM if aftermarket is available.
Reactions: TxDoc
HondaTech
The inner joint has "teeth" for the sensor to rear wheel speed, that's the main reason they differ. The LE is also thinner than a regular Pioneer.
Rhino makes Talon axles and there made the same way, i'm sure someone makes LE axles.
Gabbas
Gabbas
280
701
Humboldt, Iowa
Those guys can take care of you. They make and sell aftermarket axles.
For the LE.
Sent from my Pixel 4 using Tapatalk
