Did u use the search on here?I have seen people using gate hinge to make the gas pedal easier on your foot fatigue. I have seen a video of someone making one but I can't seem to find it.
was pretty easy to find. Got to broaden your mind. That will work on a P1
DIY Honda Pioneer 700-4 Deluxe Trail Pedal
Just saw this on YouTube and wanted to pass it along. Sent from my moto z4 using Tapatalkhondasxs.com
The on in the instructional video wasn't? 🤣Thats the one thank you
I used basically the same concept. I just had some scrap 2x4’s laying around and glued them together. It works like a charm. There’s a small piece of conveyor belt under mine to keep it from sliding around.2 x 10 board. I took this before it had been painted black. Changes the angle of your ankle and lets my short wife be able to reach the pedal with her heal on the board, rather than jabbing it with her toe which causes the lurching action.
I covered my bottom side with a piece of treadmill belt, it never moves. My buddy just ran a screw through his board and floor.I used basically the same concept. I just had some scrap 2x4’s laying around and glued them together. It works like a charm. There’s a small piece of conveyor belt under mine to keep it from sliding around.
Give'r a coat of black rattle can deluxe and she's good to go!Just got done putting this one together in about 5 minutes with scrap 6" wide pine boards and 2 wood screws. It worked good for me first time out. I may tweak the design a bit but it's pretty much good as is. Seems to stay put and still easy to hit the brake as needed. Much easier on the ankle angle at least for me.
I did kinda the same thing with a couple 2x4,so glued together side by side, and put a small piece of conveyor belt under it to keep it from sliding. Mada world-famous difference!Just got done putting this one together in about 5 minutes with scrap 6" wide pine boards and 2 wood screws. It worked good for me first time out. I may tweak the design a bit but it's pretty much good as is. Seems to stay put and still easy to hit the brake as needed. Much easier on the ankle angle at least for me.
