P1000 Maintaining dual battery set-up
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
I've searched but I can't find an answer. How do you hook a battery tender up with a dual battery isolator. Do you charge both batteries somehow? Just the secondary?
Reactions: sharp
Corona1
Corona1
319
878
The Land of Cheese
I was wondering the same thing. Thanks for asking and for the answer.
Reactions: sharp
Bubba
Bubba
100
124
Belle Chasse La.
So when the tender charges the primary up and the isolator blue light comes on and lets both batteries charge my tender keeps charging and never goes from red charging to green charged. Blue light never goes back off. Gages show 14.1 volts on both batteries so I know they are charged. The tender should go to green then! How does you guys work?
Reactions: sharp
Kenjones21
Kenjones21
164
103
Central Louisiana
mine does same thing.... How do you have your ground hooked up? I've got mine hooked to the factory battery , I'm thinking of changing the 2nd battery ground to the frame and see how the tender works then.
Reactions: sharp and Corona1
7,144
27,177
Give Dennis a call at (509) 991-0385. He is the designer and manufacturer of the True isolator. Hes in Washington state so check the time difference. He can answer any questions you guys may have .
utvmi
utvmi
265
574
Any update on this, Did anyone find out an answer to this ?/..Thanks
Reactions: sharp
ghost
ghost
993
1,873
BC
Are you sure nothing is running on the second battery while it is charging?
Try disconnecting all custom accessories and check if the battery gets fully charged.
Reactions: sharp and Delton
Bubba
Bubba
100
124
Belle Chasse La.
The light on the true isolator staying on makes the tender keep charging.
Reactions: sharp
i just charge the primary.
Once its fully charged, the isolator opens to allow charging of secondary
@ghost is Right charge the primary and the secondary will charge once the primary hits 12.8v.
I have had mine set up like this from day one and it's worked fine.
If you have a radio or something else with a parasitic drain it WILL not be able to charge the battery and will eventually kill the battery it's connected to. I learned that the hard way.
Reactions: sharp
Bubba
Bubba
100
124
Belle Chasse La.
So your main battery charges up, light comes on the isolator letting the second battery charge , when second battery is charged your battery tender will shut off ?
Reactions: sharp
Z
zin01
174
235
Royse City
I think what they are saying is that the blue LED on the true isolator is enough of a drain that the battery tender will never "fully charge" the second battery and therefor the tender will not shut off. It makes sense to me. Also I wired my winch to the second battery and the dash switch for the winch has a LED light and so the battery tender is basically supplying power to both those LED's and will not turn off.
Reactions: sharp and truc577
Bubba
Bubba
100
124
Belle Chasse La.
That's right! the blue light on my isolator is not letting the tender shut off when the second battery is charged.
Reactions: sharp
truc577
truc577
130
360
NEMO
I had the same issue and installed a master switch. Switches are cool and all, but they cause some issues
no it stays connected until the primary drops to 12.7
. No im saying if you have a radio or USB ports that stay powered 24/7 that will drain you battery.
right the isolator stays on once the primary is charged. The light is just status is maybe a milliamp not enough to run the batterys down in a year. My tender goes to float Mode once it reaches full charge.
You have more of a drain than you think somewhere try disconnecting the accessories all together and just have the batteries connected via the ISO.
Reactions: sharp
