![Coeus](/data/avatars/m/22/22310.jpg?1717412086)
Coeus
Major General
Here is the other side that has the Rokblokz installed
🤨 You need more fishing rods......😂😂😂
Troof🤨 You need more fishing rods......😂😂😂
That looks good. you are making good progress on the box pile. 👍
Do you like the whips in that location? I’m sure you had them mounted in other locations as well… (nomo)I know it's a little hard to see on mine, but it runs inside the ROPs then up into the cab:
Yeah, that’s the most vertical I can get them and still fit it in my garage. I had them mounted along the ROPS but they got beat to s*** by the bar and filled up with water.Do you like the whips in that location? I’m sure you had them mounted in other locations as well… (nomo)
trying to decide where mine should go as well (bought 3’ ones so they shouldn’t stick up too much if mounted vertically on the lower ROPS)
Working with Ian at Crossroads 3D has been awesome! Big shoutout to him... he responds to emails, refunded the shipping amount when it was actually cheaper, and provides great guidance!
I have mine mounted upside down along the ROPS. Mounts are at the top. I used 321 Stainless Steel 2" ID Snug-Fit Vibration Damping Loop Clamps w/Neoprene rubber cushions from McMaster-Carr at bottom to keep them from moving. So far, everything has stayed in place, and I have had no water in them (not sure if I added any sealant or not).Yeah, that’s the most vertical I can get them and still fit it in my garage. I had them mounted along the ROPS but they got beat to s*** by the bar and filled up with water.
100% agree. I'm a repeat customer.Working with Ian at Crossroads 3D has been awesome! Big shoutout to him... he responds to emails, refunded the shipping amount when it was actually cheaper, and provides great guidance!
Me, too. We actually worked together to improve the Auxbeam mount design for the '22+ Talons last year (not sure when you ordered yours).I used him for the Auxbeam mounts in 2 Talons, good stuff
Do I need to stop thinking your gonna get everything done by the end of next week ? Are you gonna dedicate 2-3 full days to it ?
As long as the parts arrive on time then yes I’ll be done.. testing out the dual battery and turn signal kit hopefully today now that I got the remaining parts inDo I need to stop thinking your gonna get everything done by the end of next week ? Are you gonna dedicate 2-3 full days to it ?
I’ve been looking at that tablet mount. Just don’t think it will work with the SATV flip up
Not sure either… it’s so so… one of the mounting tabs is crackedI’ve been looking at that tablet mount. Just don’t think it will work with the SATV flip up
Looks like backlight is by default so might just remove that connection then… 🤔🤔Tested out the dual battery configuration and everything on my end works as expected…
The pro kit seems to be wired backwards.. anyone else experience that? Could be the pioneer kit @Hondasxs hooked me up with that’s wired differently
Also, looks like the plug is fed by the blue key on power but the switches require and additional key on… sort confusing (but could be the pioneer vs talon setup?
