Major General 2024 Talon 1000R-4 Build Thread
DRZRon1
DRZRon1
1,403
4,333
Vondy
Vondy
1,591
10,545
Houston,OH
Also the skinny pedal is twitchy… every bump caused an acceleration and deceleration… I think I have whiplash now… any suggestions?
This the answer to the pedal.
Coeus
Coeus
Major General
75,227
686,795
Signal Mountain, TN
  2. Talon R4 LV
I’ll add that to my list
DRZRon1
DRZRon1
1,403
4,333
IMG 4989
#drzron-offroad - lol
Scoop
Scoop
5,378
21,168
  3. Talon R LV
Not too happy with the @SuperATV radius arms.. details to follow .. but the gist is the instructions were wrong and caused my tires to wear over 1/4”+ in less than 200 miles of usage..
I told you something was wrong! Far more than some negative camber would ever do that quickly.
SLOWPOKE693
SLOWPOKE693
1,996
7,753
Somewhere in Texas
I’m down about a half inch on the tread…. I’ll take some measurements and pics of all this and submit a claim
Lots of questions........
Did you match the length of the new arms to the old ones?
Did you check the rear toe in/out after you installed them?
Did it have a bunch of noticable negative camber when you were done with the installation?
I'm no fan of SATV, but how is this their fault? You installed them, there was an obvious alignment problem using their directions (Scoop seemed to notice if im reading his post correctly) and you drove it like that. Not SATV's fault and more like user error.
DRZRon1
DRZRon1
1,403
4,333
One could possibly ponder the scrubbing dragging noise of a tire that removed 1/2” of tread after the first 1/4” was gone - alignment is owner issue no matter what the instructions say - as my dad said “if someone told you to put your Winkie in a vise and close it hard’ - would you do it - lol
don’t be a victim
Coeus
Coeus
Major General
75,227
686,795
Signal Mountain, TN
  2. Talon R4 LV
don’t be a victim
Y’all are probably right but as one who is new to all this stuff I relied on the instructions to guide me… they are completely wrong and I didn’t know any better.. lessen was learned
I wanted to share this so others would learn and @SuperATV should change their instructions
SLOWPOKE693
SLOWPOKE693
1,996
7,753
Somewhere in Texas
What do their instructions say?
Coeus
Coeus
Major General
75,227
686,795
Signal Mountain, TN
  2. Talon R4 LV
Here what the instructions said… it specifically calls out measurements, not to measure thee existing rods or to check toe in/out…
I had to double-check that I didn’t screw anything up with the measurements…
IMG 6591
IMG 6587
IMG 6588
IMG 6589
IMG 6590
Not the best angle for the close up measurements as I had #1 help me… but you can see they match the instructions
Coeus
Coeus
Major General
75,227
686,795
Signal Mountain, TN
  2. Talon R4 LV
don’t be a victim
I think your analogy is not really applicable (comparing apples to prime rib)
it’s more like: you bought a widget you’ve never seen or installed and have no clue about it but wanted to try it out… and the directions said to drill a 5/16 hole in a $600 part and then you go to install the widget only to find out it doesn’t fit… as it really needed to be a 3/16 hole… (maybe not the best analogy either) but feels more accurate in my mind 🤷‍♂️
In that case who’s fault is it?
