Talon MFG,s Build
Moto4
46
51
Vermont
View attachment 178495 View attachment 178496 I finally took a couple of pics this morning. I hope this helps. Like I said I just measured the stock setup and cut my adapter several times until it had the same measurement as stock
Thanks MFG for the info and pics. I ordered the same wheel and hub you did. Est delivery on the wheel isn't until mid to late February but no problem since the ATV/UTV trails here in Vermont are closed until spring. Hub should be here next week.
Noticed in the pic that you have changed your shifter gate. How do you like it?
Reactions: IDIOT
5,760
26,451
Thanks, and yes the paddles are the same distance from the steering wheel. I can try to get a picture tonight. This is a different adapter but the picture shows what I cut off. I measured from the factory wheel before I started and then made several cuts on the adapter until I cut off enough for the new wheel and adapter to be the same measurement as stock. The splines are deep in the adapter so what you cut off does not mater.
Thank you!! It's true, a pic is worth a thousand words.
MFG
MFG
191
293
East Texas
I like the shift gate much better than stock. I have about 600 miles on mine now and need to adjust the shift cable but it very nice being able to go from lo high and revers quickly.
Reactions: SpeedBuggy
GA-TALONX
GA-TALONX
GA
I hope this isn’t too dumb of a question but is the steering wheel hub a quick release style? It looks great either way!!
MFG
MFG
191
293
East Texas
K
KenThompson
281
624
Mulino
Was there some reason you wanted the rear as wide as the front? It won’t steer or corner as well. Race cars are always wider in the front.
MFG
MFG
191
293
East Texas
Stability, we do trail riding and a bunch of hill climbing and rock crawling where the width is nice on the side of a hill. Around my area there is nothing like the open desert where guys get to run wide open for hours on end. The only time i get to stretch my Talon out, is the roads around the house. I think everyone sets up the machine different for different terrain.
Reactions: Landman
K
KenThompson
281
624
Mulino
I guess you won’t know the difference in steering when your hill climbing or rock crawling. Rock on!
