Milwaukee Packout.
Coeus
Coeus
Major General
75,451
687,954
Signal Mountain, TN
  2. Talon R4 LV
Reactions: WagginTail
Coeus
Coeus
Major General
75,451
687,954
Signal Mountain, TN
  2. Talon R4 LV
Also still interested in seeing pics/links OP asked about too… to get back on topic!
Reactions: Remington
Russ989
Russ989
22,645
147,291
I’ve been running packout for two years and I wouldn’t have anything else. It’s too easy to switch up and change compared to other setups. I run the standard plates in my Pioneer, zero issues so far.
116,565
Remmy's beer stays cold too!!! And if you have a 1000-3, you don't have to worry about the back seats........
Hahaha yes it does!
Great meeting you and riding with you at the TO.
Reactions: trigger and Coeus
Russ989
Russ989
22,645
147,291
Here’s the setup I have in my Pioneer, it works great. I also have mine mounted so I can raise the seats and leave the plates in.
1E60B6CB 0CD8 443E 85F7 BB5A5B269589
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
@Neohio the bags on my P500 allow access from the sides for the front bag and from the back for the rear bag.
(full disclosure: I stole this photo from another thread, it had the correct angle to see the bags 😁)
1655223717234
You could consider something like this for the pack out.
If the p1k bed is not long enough there are 1/2 width packout boxes that could go sideways in the front.
I was going to say I don't know how big the bed is but that's a lie, didn't bother to check.
@Russ989 do the boxes with multiple drawers seal?
1655224486979
(yep, stole that one too)
You seam to have crossover experience with packout boxes and SxS.
Maybe you could comment on what boxes, if any to avoid based on sealing, strength or whatever.
Russ989
Russ989
22,645
147,291
The drawer systems do not seal unfortunately, I’ll look at the product numbers on my boxes when I get home.
Neohio
Neohio
Beast of the East
21,734
93,036
Painesville Ohio
I might skip the milwaukee factory bases and create a plate as large at the bed floor. Make it 3 pieces so each seat is still usable. I have a laser guy at work that is dirt cheap. I prefer access from the tailgate vs the side. I don't know. I will mock up a few models and see what I think looks best.
@lee I will see if I can find a 500 local to me and get some dimensions to attach one to the 500 rack.
Tyler6
Tyler6
37
84
KY
Ordered my mount from Etsy mounted to inside of seat frame using smooth headed bolts. Mount stays in place without boxes when seats are up but have bed extender to hold boxes when seats are up. Boxes are always water tight even with pressure washer clean up. Also installed brackets and piece of aluminum bar to install rotopax 4.5 gallon jug with deluxe mounts
CF3BEC77 509F 40C6 9FDB 8522507FC58A 95459C51 0A56 40B4 B6E3 AE8D5DAB2F06 F4983D6A 56C2 4C8D 9AFA 8E1316439AE4 52E490BD 3DCA 4734 A4E8 3948A73CC641 0767E3CB 42AD 4603 8B4D 21F5C3ABD6EE
Coeus
Coeus
Major General
75,451
687,954
Signal Mountain, TN
  2. Talon R4 LV
View attachment 339186 View attachment 339187 View attachment 339188 View attachment 339189 View attachment 339190
You have a picture with the seats up and boxes?
Reactions: Smitty335 and J80
BobFarrell
BobFarrell
131
280
Arizona
I have helped 2 Talan owners install on their machines as well. Take a standard PO plate and cut back 2 corners to make it fit inside the bed. Then install your choice of boxes. It was the VERY FIRST thing I did on mine. My boxes are dirty as they used to be on the Polaris. Sold that machine with the plate installed and new owner was going out to buy PO boxes for himself, that same day.
Packout Boxes
Tramguage1
Tramguage1
Texan
7,594
31,395
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Maybe a plate that spans all the way across the front of my trailer. Then have the Hondasxs.com cutout in the center.
Tigermark
Tigermark
Outside looking in.
Neohio
Neohio
Beast of the East
21,734
93,036
Painesville Ohio
Well, little project completed this morning.
2 Milwaukee 1.5 plates mounted side by side on some random pieces of plywood I found in my garage. Truck is a 15+ F-150.
20220625 090119
So far only have a tire kit and first aid kit figured out. Thanks @Tramguage1 for the tire kit inspiration! Now to transfer all the tools/parts from a Pelican 1550 and soft tool bag.
20220625 090233
May not get the plates mounted in my Pioneer today. But the truck half was important to get done first for me. My machine is an hour away at camp for 6mths the year. So i don't typically leave tools in the back when I am not around. At least I don't have to worry about stuff sliding in the back of my truck. I hate hearing stuff slide around.
