MiniRF's 2024 Talon 1000R-4 Fox Live Valve
MiniRF
MiniRF
NTC's Newest Fool
23,438
155,898
  1. Talon R4 LV
@MiniRF, I’m sure your dad is looking down and sooo proud of his little retarded girl & laughing his butt off at MrMiniRF 🥰😜🥰😜
L1ug5sWBCJOOGzN84
MiniRF
MiniRF
NTC's Newest Fool
23,438
155,898
  1. Talon R4 LV
Got the Mud Busters installed. Overall a fairly easy process but I will say all of the hardware was thrown in a single box and the different sizes were not labeled. If you order these, I suggest separating your hardware into the different sizes before getting into the install.
20250407 200532
Messenger creation B6986067 147C 45A3 9AD1 FBCBBBB56433
We also ordered the rear mud guards but we have yet to install those as they will cover the brackets for the tree kickers I am going to install. I hope they will fit once tree kickers are mounted.
906UP
906UP
15,060
143,142
da Yoop
I took my rear mud guards off, I found they held more mud in than anything, at least with them off you can wash out that area.
MiniRF
MiniRF
NTC's Newest Fool
23,438
155,898
  1. Talon R4 LV
The @SuperATV rear windshield arrived and the box looks like it's seen better days. Hopefully all is well on the inside, I will open it up after work to check.
20250409 111730
20250409 111612
MiniRF
MiniRF
NTC's Newest Fool
23,438
155,898
  1. Talon R4 LV
There was not much packaging in the box, one thin layer of bubble wrap but from what I can tell the windshield seems fine and....you're not going to believe this....but there were stickers!!
20250409 203626
MiniRF
MiniRF
NTC's Newest Fool
23,438
155,898
  1. Talon R4 LV
Got the front of the Trail Armor skid plate bolted up.
Since we also have the SuperATV frame stiffener, which covers the mounting points for the 2 front bolts and T nuts, we needed to use a heat gun and clamps to bend that plastic up, drill through the frame stiffener and then bolt it on.
Thank you @Coeus for the guidance on this one.
20250410 181732
Scoop
Scoop
5,439
21,387
  3. Talon R LV
China loves you. 🤣🤣🤣🤣🤣
In many cases, you can't FIND an American made product on the shelf because they don't exist.
Thank Bill Clinton and the rest of the 90's politicians for NAFTA. That's the primary reason the big companies moved all their production south and overseas, which is directly responsible for destroying American businesses, small towns in America, and millions of American families. As painful as it may be right now, it's exactly what the Trump administration is trying to reverse.
