P1000 Mounting Pho
Jbird
Jbird
392
475
Mena, AR
Can anyone post pictures of how you mounted a spare tire and extra fuel cans on the P1000-5 ?
Also a fire extinguisher if you have one. Thanks.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Fire extinguisher??? Try the RZR forums lmao
Sorry I couldn't resist lol. Several members have good rear mounts for tires and extra gas. I just have a storage area next to the spare but it holds a 5gal jug perfectly. I'm actually gonna have to make another one so I can move spare to center of vehicle. I want to go street legal and need the tail lights unobstructed. Joey has a great setup
Here's my spare tire and Roto-pax mount. Extremely easy and cheap to build and nothing permanent on the pioneer.
Built using scrap I had laying around. Getting primed this picture.
1b5469ddab271959c93a4479350da4b7
Here it is painted black and installed in the hitch.
B91275d6a9c3bfcfb9625e49eca40206
I tried to get the tire and fuel can close enough together to not block the taillights.
723a4257590aeeb1079a3d5ddce1dfec
It tucks in nice and close
2e3b2fc7b8c21aaafdfeb3c3caf8f852
I use a ratchet strap to keep it from swinging. The strap isn't installed in this pic but you can see the loop for it.
2b7e9444c8dca98b596f7c4bb25ac7f4
This tire mount has proven to be strong. It has survived royal blue and Bull Run many times.
C8f817a35d901e7849628df77401bd0e
For the fire extinguisher mounted, i mounted it to the ROPS in the rear on the drivers side.
55d1162cd3efccdb0b4f06c54d750dc4
Here's another view
Db57fdc0191abb33ac2d379f21258f17
Jbird
Jbird
392
475
Mena, AR
Your whole friggin setup is exactly what I am looking for! So cool! Have you thought of making these for sale? If not do you think you could post a dimensional sketch with lengths, angles, etc? I have a friend with a welder. Also who makes the fire extinguisher kit you used. Also do you know where I can buy "one" spare deluxe tire and wheel for my P1K-5?
What size Ropax did you use?
Reactions: CumminsPusher
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I like your mount test lol. If it didn't fall off during that, I don't think it will
Reactions: joeymt33
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
If you're into a swing out design, this one was super easy to make and cheap ( also made from scrap metal laying around).
IMG 20160713 094244420 800x450
Reactions: DGann and joeymt33
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
We tested mine too lol. If anyone is concerned about a mod they've created, just bring it to the Northern Alabama testing grounds and it'll get put to the test. We make Redstone Arsenal look like a kindergarten class lmao.
7897 800x448
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
We actually did 2 tests in this shot. Shock test for mine, splash test for Joey's lol. It's waterproof. Just like his phone.
I'll try to get to that here in a little while
I haven't had a chance to do a sketch but you and your friend could probably make this pretty easy. I did take a few measurements and some pictures when I went through the shop this evening.
3e95decf0efb8554c8a89c72fb186345
05d3e8971ae308a2a8e01b3c6842e15c
B44c04a671c757cbc4c565e292b69532
94f1192d2ffd2f15442c0df912c8250a
94711dcf080f928dcaf03237ee243c7b
4a0aebeae62c8b204f7dd2c7fb7a15b6
126cd0da85b0b7dfb3d01daa7b2a476d
This angle is approximately 32°
9f3f8a35969e396faad85b388af77b51
Here's a picture of the fire extinguisher I used. In the picture you can see a part number for rockymountainatvmc.com.
There are many different styles available. This one seem pretty handy because it came with the bag and straps to mount it.
Cdc0c33284392a237498f2e6f669f600
I used 2 gallon Roto packs. The mount will hold two of them.
As for a spare wheel and tire, you could post in the buy/sale section on this forum or buy A wheel and tire from Rocky Mountain ATV from your local dealer.
Reactions: DGann
One other note on the spare tire carrier, I will be adding a gusset near the bottom. When you think about the weight this thing is carrying and all the bouncing around, you can add a lot of stress to this Weld. I usually have a spare tire and 4 gallons of fuel and ride pretty hard. All that bouncing around has created a stress crack.
Ec50857366f31cf65ddea741ca4fb2da.
Thanks to you, I noticed this crack. If you had not asked me to give you some measurements, I would not have looked at it close enough to see it.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
View attachment 18630.
Jumping head first into creeks will sometimes cause this. Or so I've heard (wouldn't actually know) lol.
To the OP, Harbor Freight sells a receiver extension that'll make your life slot easier building this. One end fits into receiver on our machines then it goes down to same OD as 1.5" square tubing. I can take a pic of the one I bought if it'd help. I'll probably end up making one like this when I go street legal with mine.
Reactions: Jbird and joeymt33
