P1000 My forever trailer
swsebek
swsebek
2,854
5,835
pa
I like the loops and I would put 2 behind and 2 in front with ratchet straps but split the weight over the 2 axles and it will haul better for you
IMG 2654 IMG 2655 IMG 2693
These are the straps I posted.. they're heavy! And notice the angle of the straps... FYI.. you don't want the machine coming forward into the cab if there were an accident. If you look close there is an extra safety strap hooked to the hitch.
Jshell3
Whelp...
I'm making an adjustment.
Buying 4 more D rings (cause I like them). 2 more ratchets (cause I like them, too) and bolts!
Leaving the original as I've posted for times when I will haul a second ATV and extra anchor points are always helpful.
But I'm going to center weight BB above the tandem axels and spread anchor points for good forward / backward tension from ratchets.
(I'm not THAT concerned w the way I have it now, but I've not hauled much around steep angles. And I can see how letting the trail do its job would be better for my trip)
So thanks! I mean that.
Will update.
IMG 0002
Jshell3
View attachment 40513 View attachment 40514 View attachment 40515
Imma do this.
And then when I pull up to RRB, you'll be jelly.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
They don't give em' away
Reactions: trigger
Jshell3
Tramguage1
Tramguage1
Texan
7,516
30,872
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I guess I never really understood how to use wheel bonnets.
But I see now how that would be pretty fancy.
Before I'm done, I'll have several configurations and scenarios that will fit anything from 1 atv to a full living room suite. LOL
Thats the spirit, be ready for anything!!!!!!
Ragnar406
Ragnar406
The Great Bald One
4,450
17,037
Bella Vista, AR
@Jshell3 I hear ya, I am still trying to find the perfect tie down combination. I have a tandem trailer and keep positioning the pioneer a little different to try and find the perfect place. While I have a straps that I use I know the positioning is not optimal. I really want to lay some etrack and get wheel bonnets - kind of like @my99svt has - but with Etrack
