P1000 My forever trailer
As we were talking about chains or straps coming loose from over the hitch.. I saw this at TSC yesterday!
IMG 3567
Tramguage1
Tramguage1
Texan
7,516
30,872
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
That looks great to me. Now if you need to move the weight forward or back, its just a matter of changing the strap lengths.
Reactions: sharp and Jshell3
Tramguage1
Tramguage1
Texan
7,516
30,872
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
You could always bolt one of the D-rings here.70d9dbdfb642506ebfa3f0f9f2ac8c20
Reactions: sharp
Ragnar406
Ragnar406
The Great Bald One
4,450
17,037
Bella Vista, AR
Not to mention, this setup allows various load centering options...
And it does pull better than all the weight on the tongue.
Thanks for the input, guys!
What size trailer do you have? I position mine like yours is shown with the real wheel over the 2nd tire. I have a 14' tandem with a heavy ass gate. Guessing you have a 16'
Reactions: Jshell3
Jshell3
Yep... I took in on a test drive down a rough section of road...
I will have to keep an eye on tensioning the straps. (Different than using chains).
Jshell3
Yep. 16' with same gate description. Heavy!
Tramguage1
Tramguage1
Texan
7,516
30,872
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
@Jshell3 just my 2cents, i put straps through the spokes of my tires and then ratchet strap to anchor points. This allows the Pioneers suspention to obsorbe the road bumps. 0b4af4c43ec4bd0e029bf9aaab59812e
The only thing I can say is make sure your bumpers are clean when you wrap your strap around them.. you don't want something abrasive rubbing your strap or bumper. That's why I used the d-rings on the front and rear. I like metal to metal. But if you're using your straps looped the way you are, it's probably best over the bumpers.
IMG 2801 IMG 2802 IMG 2804
69,905
@Jshell3 just my 2cents, i put straps through the spokes of my tires and then ratchet strap to anchor points. This allows the Pioneers suspention to obsorbe the road bumps. View attachment 40703
Thats sounds like a good idea to go through the wheels I may try this.
Reactions: Jshell3
208,731
Dang! That was the color of my Z71, RIP. And the d rings are what I have on my trailer, 6 of them.
Reactions: Tramguage1
