My Idea for plow angle changer from in cab
swsebek
swsebek
2,854
5,828
pa
I have really been using my plow lately.But I want to change the angle from inside the cab..800 bucks for hydro turn,:eek:and it looks cheap and weak....so I have this Idea that I had made years ago......I gathered all the stuff and now this weekend I will start the build........
I collected alot for different types of cables,from mowers,bikes tractors,and old R model Macks.
and what I came up with was theses cables that run the lift to rolloff trucks.These cable allow you to run the hydralics from inside the cab and they cant be ripped in half by hand.They are very strong and smooth and easy sliding.they have a large diameter and theaded on both ends with a larger threaded area above the other.....pics are coming!!!
swsebek
swsebek
2,854
5,828
pa
IMG 3300
IMG 3314
IMG 3315
swsebek
swsebek
2,854
5,828
pa
I'm mounting this on one end
IMG 3301
Reactions: allgm1
swsebek
swsebek
2,854
5,828
pa
And it will connect to lever on plow that you push to change angle. But in stead of pushing I am mounting it so it pulls up and the yellow X is where I will drill hole to mount.
IMG 3302
IMG 3303
IMG 3304
Reactions: allgm1
swsebek
swsebek
2,854
5,828
pa
I will cut this angle and bolt under here. And drill a hole to put cable through and tighten to it.
The cable will go through grill and passed Radiator and look like this
IMG 3306
IMG 3312
IMG 3313
Reactions: allgm1
swsebek
swsebek
2,854
5,828
pa
IMG 3309
This will be under dash to just pull and it does pretty easy.When it's pulled you can let the plow touch off the left or right of area you are plowing and the snow moves it or rocks like I plow:Dthen just let go and spring on plow clicks in slot and you don't have to get out....:)
Reactions: trigger and allgm1
swsebek
swsebek
2,854
5,828
pa
the pic makes it look huge...but its fine thread 5 1/16 on ends so you can use this black handle or make one.
swsebek
swsebek
2,854
5,828
pa
IMG 3321
IMG 3305
Above where it lifts the lever I will make a bracket that I will weld to plow that will hold it like the orange thing is showing. This weekend I will make the brackets and hopefully be able to paint and try out.....
Reactions: CumminsPusher
swsebek
swsebek
2,854
5,828
pa
I know I have a lot to desire for typing my description.... but the truth is I can build this stuff easier then it was to take these pics and try to post what's going on in a thread....
swsebek
swsebek
2,854
5,828
pa
I also thought if someone wanted to go a different route or you have a different machine you could use a bike cable and hand lever like a clutch and mount a pipe so you could squeeze it like a clutch on bike to pull up lever on plow.and there is push mower cables too.But these that I used seem to be the way I'm going
IMG 3316
IMG 3317
IMG 3319
swsebek
swsebek
2,854
5,828
pa
IMG 3304
IMG 3311
The cable looks ok and flexes really tight and still no binding. It goes behind shock and through plastic above brake pedal and under steering wheel.........Yes I'm sure someone could start patenting these and make a killing on different machines and anything with a plow. But I'm not that guy.....Hope Just one person gets the Bug to do there own and I was the inspiration for it.
swsebek
swsebek
2,854
5,828
pa
IMG 3123
Also was playing around with some Leds From Wally World for under hood and grill.mounted them on aluminum and put another piece on top. They make the whole hood glow.....In the snow it looks neat..... the box In pic is white lights but the reds are what I got 4 20 bucks.....
IMG 3205
IMG 3298
IMG 3299
E
elkguide
3,377
7,963
Vermont
Very creative!
Reactions: swsebek
13,364
65,123
Looks like you used a standard PTO cable.
Great Idea. I will have to look at my plow and see if I can fab something similar.
Reactions: swsebek
swsebek
swsebek
2,854
5,828
pa
IMG 3376
IMG 3377
IMG 3378
IMG 3379
IMG 3380
IMG 3381
IMG 3382
Well I had some time to make the bracket to hold the cable and bracket to lift the lever. Just got it tacked but it pulls very easy... tomorrow I will start to make the bracket under the fender.
jinx
jinx
565
528
Looking good. Love watching a pile of saved items become something.
I know I'm guilty of saving plenty of things that most people might pitch lol
swsebek
swsebek
2,854
5,828
pa
IMG 3385
Well I changed the bracket and Location for the pull handle.... didn't want to drill frame or weld to it. So I made this easy aluminum piece and siliconed the back and bolted it to here.Loc tired them little bolts.Then drill the hole 3/4" to allow cable to go through..
IMG 3386
ThenI used washers and a piece of rubber gas line to keep it snug
IMG 3387
IMG 3389
I measure the pull weight and it's 3 lbs.
Very pleased how it looks and works...
swsebek
swsebek
2,854
5,828
pa
Now I don't have to get out to change angle...
Ready to start my doors.;)
