brettc
@mlynch001 Can't believe I've never seen your build thread before, what a story!
Im new here. Just purchased a pioneer. I’ve never posted a “build”. I’ve been very busy the last 2 months. Constant work. But very happy with the results. Very happy with the Pioneer!Can't believe I've never seen your build thread before, what a story!
Yes. Made the cab 25% quieter on a conservative estimate. Also cut heat down. Which is not great where I’m from. But the noise reduction was worth more to me then heat as I installed a heater core system that works amazingSound deadening?
@robdaigle This is the build thread for mlynch001, that is who I was replying to.Im new here. Just purchased a pioneer. I’ve never posted a “build”. I’ve been very busy the last 2 months. Constant work. But very happy with the results. Very happy with the Pioneer!
Haha oops.@robdaigle This is the build thread for mlynch001, that is who I was replying to.
Is this the one with the clipboard under the console lid? Don't see it on TS website but I found one that looks the same on Amazon. TIADid thisa while back and just got around to posting today while snowed in here in Arkansas. Found this console at Tractor Supply. My wife has been asking for one for a long time. The center seat belt is a perfect "retainer strap" for this console. If we need the center seat, we just unbuckle the seat belt and pull the console out. Works a treat! View attachment 317484
That is the one. I think that TS no longer carries this item.Is this the one with the clipboard under the console lid? Don't see it on TS website but I found one that looks the same on Amazon. TIA
Glad I could be of some help.considering the same System 3 SB4 Beadlock wheels and System 3 RT320 DOT 8 ply.
A: Curious how you are liking that set up so far and how they are holding up?
B: In post #40, you answered DIRISHMAN with a post that is helpful to me... My question is this (and i've researched here but i'm still a bit confused)
1 - I want same track front and rear, i also want same size wheel and tire all around so I can rotate as needed.
2 - What offset wheel do i need on all for corners and what size spacer in the rear to give me a stable ride and same track from the rear.
Notes:
- I don't really need a much wider track than factory, but i'm open to it if it makes sense (I assume huge spacers are not super kind to some suspension components?)
- I will likely consider SATV forward A arms but don't need a lift. (mostly a farm machine with occasional camping trips). (Will also add RC shocks once these are tired)
- Am adding frame gussets to the upper a arms as well - can't believe how weak this part of the design is.
You are welcome, I do not believe you can have "too much" information before modifying a vehicle.@mlynch001
excellent write up and information.
Thank you so much!
my new to me 2020 is mostly a farm vehicle w/ some occasional camping trips and trail rides.
(my 2018 had a frame tear and a arm tab failures after a minor impact so i'm definitely wanting to strengthen the a arm areas)
Some others have also given me some good direction here, i'm trying to figure out the best way to go w/ offset/wheels/tires etc.
learning a lot.
Hoping to be able to rotate tires as needed for wear which is mostly driving my query.
it sounds like the 5+2 is a decent way to go and gives same track and be able to rotate.
Some really like the RB3 spacers and it seems for most, they are needed in the rear.
I'm of the same logic regarding extra load on the machine and would prefer not to have that.
also, am wanting as few failure points as possible.
perhaps 1.0-1.5" on the rear only isn't too much. not sure what others have experienced with spacers but i've read of occasional failures
at any rate, thanks again for the perspective.
