P500 My rig build...
Yep, you discovered the tippy nature of the P5. Just have to deal with it and learn the way it responds to the terrain. There's plenty of discussions on this board about things which you can do to improve its stability. Good luck with that. Still can't get over that color!
Jshell3
@Jf500 Is the top of your steering column painted to match your hood? Am I seeing that correctly? Looks Green in the pic w the bow in the seat.
And also, Honda does a terrible job with accessories installation instructions... but the little rubber pucks in the roof clamps are for shipping purposes and should be discarded prior to roof installation.
(Or so I read... kudos if you made it work. I could not. )
Reactions: JTW
Jf500
32
66
New york
Haha must of been the lighting but it's not painted to match although now that you pointed it out that wouldn't look too bad. The instructions were non existent! Just kinda went for it. I figured the rubber pucks will cut down on vibration noise. It wasn't difficult to get them in at all.
Reactions: Jshell3
Jshell3
Yeah... I though about painting the top of my steering column after that pic... it DOES look pretty good!
Roof Installation Link HERE... (you can thank HondaSxS for compiling the instructions... It's a full time job, for sure!) I had to consult this documentation when installing mine, because of the tabs.
Jf500
32
66
New york
I love the color!! Got something in the works to add to it... Not gonna let that one out yet... I wish there was a roll cage "drop" or chop out there. Try and lower the center of gravity a bit. Especially with what I have planned. I have a buddy I'm going to be talking to that is good with fab and welding. At least much better than I am.
Well maybe it will grow on me. Folks have chopped the top. It's been discussed on this board with photos. Chopping 4-6" out of the cage isn't really going to do much to the COG. Sway bar removal is the easiest (and free) mod you can do with the best benefit. If you don't haul it in the bed of your truck, or ride restricted trails, add spacers to your wheels (with minimal risk) install offset wheels, install wider tires. All will provide increased stability.
Jf500
32
66
New york
I plan on adding weight to the top if my roll cage plans work out. So the lower that weight can be the better. I'll have to check out the chopping threads.
Reactions: JTW
Yes, for someone that's going to add weight to the roof ?????, obviously the lower the roof the better. But again, if you don't haul in the bed of the truck, or ride restricted trails, going wider is the best defense, and loose the ASB.
158,262
You can add spacers and still put it in the back of a truck. Loaded Side
rocmar
rocmar
4,741
5,773
4 CORNERS
No vibration. ....
if so your not tight
enough....
158,262
Can you take or have better pics?
Loaded with RampsHere you go.
I had ramps built, laying in bottom left corner, and was prepared to drive over the wheel wells. It may have rubbed a little but I have a Line X liner and didn't notice any scuffs on tires or anything.
26" BH 2.0 's on stock wheels w/1" spacers.
View attachment 25184Here you go.
Love those folding ramps. Steele or aluminum?
doolin64
doolin64
187
278
Impressive setup especially with those ramps Trigger. But I have to ask...why the aversion to just using a trailer? no tailgate removal, no big ramps to mess around with. Just a question. Certainly not knocking your choice. I have no choice with a 5.5' bed.
158,262
I have a trailer that I normally use.
This set up is for pulling the travel trailer too...little 18'er. Loaded Rear
