P1000 My take on the 1000-5D
Scooterchris
No longer active.
Dec 25, 2015
396
237
Deltot: 37466 said:
This is stopper for the front. It's on the door itself. Turning it counterclockwise will back it out to eliminate rattles. If you back it out too far the door won't latch properly. It's a double click design so keep that in mind.
Double click design?
Any idea about the washers on one side and not the other?
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Double click design? That means it latches twice. Not sure what you mean by the washers. I'll go out in little while and look at
Means it actually latches twice. If you shut door slowly you can hear both clicks. No idea on those washers. I'll go out in little while and look at hinges.
Reactions: Scooterchris
Scooterchris
No longer active.
Dec 25, 2015
396
237
Ok let me know please
F
Flyingpig
16
7
The Honda owners manual said not to use a pressure washer on the 1000. Not sure what electronics it might affect.
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
Well I have no choice the mud around here won't come off without one. Can't believe they have that in there.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
It says it can damage certain parts of it. Guess the trick is knowing which parts they're referring to. The ecm is under the seat along with other electronics. There's no way I could get mine even halfway clean without a pressure washer. I only spray the body and suspension with it. And I use the general purpose nozzle not the max pressure one.
Reactions: CumminsPusher
F
Flyingpig
16
7
I was set back myself when I read that know that everyone uses a pressure washer on there machines.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Maybe that's just Honda covering their rearends by putting that in there. I don't know anyone that doesn't use a pressure washer.
tundraman
tundraman
141
175
I use a wide tip 40 degree and keep it further back from the machine to reduce the pressure. How you use it is important and things not spray such as cv boots, etc. will help prevent damage.
Bradmc87
Bradmc87
24
34
Conehatta, Mississippi
I did notice all 4 doors rattled thru rough terrain. What are the simple door stoppers your talking about. Could you post a picture please. Also have you noticed that on the door hinge theirs a metal washer on one side and then a huge gap on the other side. Washer missing?
On my 700-4 I put electrical tape around where the door latch meet the holder thingy. Solved my door rattles.
Scooterchris
No longer active.
Dec 25, 2015
396
237
The rubber stopper he suggested fixed the side to side rattle BUT the door still rattles up and down because of no spacer/washer on the one side. Its weird how honda only put it on one side
Reactions: Bradmc87
Scooterchris
No longer active.
Dec 25, 2015
396
237
Here you can clearly see what im talking about. Needs the washer on each side to eliminate wobble
Reactions: Bradmc87
nbomar
nbomar
4,416
17,854
Springdale, AR
I did this tonight on my 1000 on the bed latch and the rear doors. All the rattle appears to be gone finally.
Reactions: Bradmc87
