P1000m5 Mystery Oil Leak Found.. Thoughts?
nerd
nerd
53
128
KY
Awhile back when strapping my pioneer down I noticed a small amount of oil on the driver side frame rail towards the rear of the engine. I hadn’t noticed any oil where I park it so I wasn’t overly worried - I assumed it was some overflow from when they checked/topped off fluids at the dealer when I took delivery.
Fast forward to today, a few weeks later and maybe 50 mi or so, I’m putting on skid plates and noticed it again. I thought WTF is leaking oil? I took apart some plastic and found a bolt and washer sitting in some pooled oil right next to the oil dip stick. I pulled back a plastic panel and found some threads and place for a bolt - see pics. It has pink paint on both the part and bolt.
My question is - what part of the engine is this? Is it a problem that bolt was gone and some oil leaked out? I checked oil level and everything is fine.
I’m going on a trip this weekend but don’t want to head out of this is an issue. Thanks in advance
B7995576 062D 459F A05B DB6C0812108E 8C759FAE 640F 4854 BC31 BC3DB6892F16 9F50AB03 E18E 4956 955C B2F51F8A3FA6
Neohio
Neohio
Beast of the East
14,588
73,848
Painesville Ohio
Part of the thingamabob? I don,t recognize that location and cant picture it in my head.
66,871
Unless you have been in deep water or something I would not worry if you only lost a little bit of oil.
It is just a "plug". It would be remove to loosen the tensioner when installing the cam chain.
Its has no other use then that, a plug.
Tighten it up and ride on.
Plongson
Plongson
271
1,027
Southern Utah
++10 Right on the mark...
Might'a should'a have a copper sealing washer under it though.
Reactions: nerd and Hondasxs
nerd
nerd
53
128
KY
Yep, I think you are right.
Here it is - 90442-397-000 WASHER, SEALING (6MM)
Thank you all!
It had a flat regular washer. I put it on and tightened down.
No deep water, just up to the floorboard, so should be in good shape I think. Oil still had honey color - only 90 mi on machine anyhow. I’d say it was no more than 1-2 oz of oil lost. Still confused how it got that way, and never bounced out or anything??
THANKS EVERYONE
Reactions: JTW
nerd
nerd
53
128
KY
And, of course, no more oil leak - alright!!
43,070
Sorry... meant to mention that it was just a plug in my 1st post but was in a bit of a hurry. As long as the threads are ok, should be fine.
Odd that it came out.
Reactions: nerd
