P500 Nasty growl or "rocks in a box" noise on hard braking - HALP
L
lukebuz
45
116
Bowling Green, KY
Hello! First post - and glad I found this forum! Going to buy a rubber noise mat (if not too late from Trigger).
Anyways, hoping you can help a bit. I have a 2017 P500, about 500 miles on it. Had it since new, and it's had a fairly easy life, with just a little firewood hauling now and then.
The problem that just occurred is a really nasty growling/clunking/rocks in a box type rattle when braking quickly. Good example is I have a 1/4 mile drive to the mailbox, and I'll be going 25-30 mph, 5th gear. If I stop normally, it growls and makes a little noise. If I stop quickly (enthusiastic driving) it goes from a little noise to the much louder concerning noise I'm now hearing.
It's a new noise - just started a few days ago. I did the 75w-140 front and rear oil changes suggested here. While super easy, it didn't change anything.
Along with oil change, i've also verified there is nothing blocking the rotor or caliper (it's clear), and I've also washed off the dirt and grime (just in case) and also no different.
Can anyone help? Ideas to check?
Reactions: Isaiah and trigger
5,406
24,778
Have a closer look at your brake pads, sounds like at least one pad is gone and you're metal to metal. Shouldn't be at 500 miles but you never know.
42,986
Check the pads and for rocks or whatever stuck in the pads, but it's probably normal. 500 and 700 have very similar rear diffs, and this noise is common in the 700. 500 also does it, but not nearly as bad.
Reactions: trigger and CID
L
lukebuz
45
116
Bowling Green, KY
Thanks, both. I'll take a much closer inspection with a mirror to the caliper and pads, and see what I can see. I'll update shortly.
DG - I'll also be doing your oil change cut-out. Thanks for passing on good tips!
Reactions: CID and trigger
L
lukebuz
45
116
Bowling Green, KY
Well, can't see jack in the rear - going to have a pull the caliper, and looks to be a PITA. Will do it in the next day or so. Will pull front wheels, looks to be easy just to see what I see...but I'd expect them to be fine. I will post back after I take a peek.
I totally get the the noisy diff - mine is noisy too, but this is redonkulus if from the rear end...
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
mine will do it from time to time mainly in 4wd and going down hill quickly and hitting brakes. I pulled all pads and replaced them even though they were in good shape. I mainly just gear down so i never investigated further.
Reactions: trigger and Isaiah
L
lukebuz
45
116
Bowling Green, KY
KYhillbilly - Did you have any change after swapping your brake pads? I'm not fond of wasting time and bloodying knuckles for no reason...
But, this is strange. It's a new noise - never did it for the previous 2+ years, and then it just started. So strange.
Also, add another KY member. I'm down in BG, KY.
Reactions: GrnP500 and 100Acre
42,986
Your sig(nature line) says Present: 2015 Pioneer 500, Past: 2014 Pioneer 700-4, needs an addition, doesn't it? 🤔
Ah...ok. These days I'm 95% on the phone, and in vertical mode the Sig's don't show. So I forget about them.
104,850
Starting at about 32 seconds...
Mine started making this noise too. I've already changed the pads in the front but not the rear.
JimmyA
JimmyA
1,644
5,504
Northeast texas
Mine make the same noise going down grades! Could be the way the gears are cut in the rear diff? I'm living with it.
Reactions: trigger
42,986
It's "gear lash". A consequence of having the rear brake on the drive shaft. A slip and grip cycle that resonates in the tiny bits of slop in the components. Sounds like unwashed ass, but is completely normal.
