P1000 Need new shocks an susp an much more.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I can recommend with confidence... the Elka Stage 5 shocks will NOT disappoint! I had my first ride in them today, and all I could think was "dang, this is like cheating"! They blew past my lofty expectations and turned my p1k into a race car!
20161217 125153
20161217 125137
20161217 112415
20161217 112328
20161217 112319
20161217 124756
Kenjones21
Kenjones21
165
107
Central Louisiana
Did you notice if it gained anymore height with the elka's?
69,244
Oh... another thing, would the lift change the shock length needed?
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
sorry, I added a highlifter kit at the same time, so I never got a chance to notice.
Reactions: JTW
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I'm not a shock building expert, but I think the answer is no. I had my shocks built for a stock configuration and its perfect with the highlifter. I could probably soften things up just a bit, but I'll wait and see how much they "settle in" after a break in period.
Reactions: JTW
I'm not either.. completely out of my wheel house!
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Just curious did not the preload adjustment give you enough lift that you needed highlifter kit to?
Stage 5 Elka's are on my list of mods so I like hearing positive results.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I'm not sure how much I can get out of the preload. I added the highlifter mostly because I wanted the stiffening in the front end. it has a bracket that connects the 2 top-front shock mount locations together making the front end stiffer vertically and laterally.
I do plan to stiffen the front preload some as an experiment... I will report back once I see how much lift seems available.
Reactions: GPR1500SC
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
I have the high lifter in already and thought I would take it out when I did the shocks because it would not be needed but hadn't given the extra support a thought defiantly interested in your results.
Reactions: PioneerPete
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I'm tickled s***less with the new set up! You can see it over in my build thread, The Making Of Pete
The shocks really made the difference, but the lift feels nice too... definitely get less water in the floorboard.
The pioneer is like a different ride now. I used to always run manual mode in the woods so I could check up for rocks or big bumps, but I can run low auto now and just rumble on through stuff. Can't say enough good things about that mod.
Reactions: joeymt33
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
With the stock shock mount setup you get around 3/4" lift when screwing down the top collar 1/2" on the elkas. You can screw it down 4"+ if you want but you will not have much droop travel and a lot of compression travel. If you add a HL kit to it it will stiffen up the spring rate, lose a little travel, limit the up travel some and increase the droop some but will keep the shock travel more centered in the stroke like stock.
Well said. I had a high lifter at one time and that part you mentioned about loosing travel....well it meant broken shock mounts on the P700.
It looks like the HL for the P1000 is one of the top lifts though. And has proven to be very reliable.
Reactions: JTW
If you do I'd be interested in buying it from you!
