P1000 New door hinges
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Looking good!!! Not that it really matters but my OCD would have to bring the rear of the door down about an inch where its even with the top of the bed.
Thats our first set second set is better
20170910 103202
walexa07
walexa07
396
380
Louisiana
Interested - how much for a set of doors? Also, is there a way to just tighten the factory doors?
Thanks,
Waylan
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
Thanks,
Waylan
You can adust the stricker for the door pm me if you are interested we can talk. There is a guy here making nrlew bushings for the plastic doors to help tighten the bushinhs
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
He is a look at the bushing replacement. I will have more pictured later on showing them and the old one. As well as a picture of doors mounted with these.
@knuckledeep
Bushings
walexa07
walexa07
396
380
Louisiana
I've got electrical tape wrapped around the bar that the striker hits to take the rattle away, but am still interested in bushings to tighten the doors if they are available.
Thanks,
Waylan
Reactions: Plumber32
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
Make sure you check your rear latches where the dump bed is. I adjusted the ones under the bed and it eliminated alot of extra rattle. Whoever installed it made them not even line up correctly.
walexa07
walexa07
396
380
Louisiana
Yes thanks for the tip - I adjusted my bed 'tight' to eliminate that rattle as well. I really don't have any rattles. If I load the bed with a couple hundred pounds of deer corn it will squeak some, and I have to put new electrical tap around the striker latches once every few months, but other than that it's pretty quiet.
Waylan
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
Were thinking about making a rubber doorjam so you wont have to use electrical tape. Just a thought right now. Would mount on your roll bar between the two door more than likely
walexa07
walexa07
396
380
Louisiana
Would there be a rubber doorjam for the front and rear doors? Or just the front?
Thanks
T
tbaker
365
637
NW. Georgia
RB3 do you have a web page to order this stuff from and how bout some front wheel well liners you can do it I will take a set
SundayRdr
SundayRdr
575
1,179
McMinville Tn
The bushings are in production this week. If you grab you door to you pioneer and lift up and down there was alot of play in the door. These bushings tightened it all up and took away almost all of the play. They are easy to install and work great. Hope everyone has a great weekend.
What about us 700 peeps? My driver door is floppy from a sloppy hing were I throw my foot up on the foot rest and lay my leg over on the door.
Reactions: Mudwing
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
Yes they are a 2 piece @knuckledeep. Slip one in top and then the bottom and they push together in the middle. But they have a double flange unlike the stock one which only has a flange on the bottom.
Reactions: knuckledeep
walexa07
walexa07
396
380
Louisiana
When will the bushings be available for purchase?
Waylan
