P1000 new to me 17 1000-5 problems
brushybarry
pikeville ky
just picked up a 17 1000-5 with 460 miles. got it home, rode it about 3 miles up and down the road and it went all to s***. wouldnt pull, once it got warm it was like clutches were slipping, oil light came on. Id stop and wait for about 2 minutes, fire it back up and it would go again for a couple minutes, no oil light. once home i let it rest for about an hour, tried again up and down my driveway and it seem to run fine. supposed to take it on a ride today but damn sure dont trust it now. I test rode the machine longer before I bought it than I did when it went crazy and it ran like a new one. any ideas??
Reactions: sharp
115,720
Sounds to me like something is out of wack/adjustment like the shifting cable possibly? I’d check under the machine and check the driveline to see if anything looks out of the ordinary. I’m sure it’s something fairly simple or nothing the dealer can’t fix I would assume it’s under warranty still?
Welcome BTW from the Great Lakes State. I see your from Pikeville? Most of my relatives live in Nearby Prestonsburg area, (Maytown) I use to spend a lot of my summers as a kid there and Loved golfing at Jenny Whylie state park. I love it down there. I’m sure you’ll figure it out of somoeone will have the answer on her. Keep us posted if you happen to get it on your own;)
Reactions: sharp
Todd627
Todd627
56,720
619,275
MI
Another welcome from The Great Lakes State :D
Reactions: sharp and Remington
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Check all the oil levels, check for leaks, look over wiring make sure a mouse didn't chew something or that a wire didn't come loose. Really an odd issue. Did the temp light come on? Take a pic of what lights did come on.
Reactions: Remington and sharp
Neohio
Neohio
Beast of the East
14,587
73,820
Painesville Ohio
Try the clutch reset procedure.
Like @Cuoutdoors mentioned. Confirm oil levels first according the manual.
brushybarry
pikeville ky
fluid levels are fine. looked over all connections and dont see anything. It runs great for about 15 mins then its like it just falls out of gear and the oil light comes on. turn it off wait a minute then restart, no oil light and it will go in gear and drive for around 15 seconds and it does it again. shut it down and wait an hour or 2 and it takes off like a brand new one again.
Reactions: sharp
complete guess but sounds like there is a clog somewhere that is preventing full pressure in the full oil system.
First time Ive heard this example. Have you checked the pickup screen in the oil pan?
Reactions: sharp
HondaTech
Sounds like a clutch issue. Whether it be a sensor or contamination.
It sounds alot like the 1 I had that was under water. Worked ok until It warmed up then would stall and wouldnt take off again till it cooled down.
Reactions: sharp
69,050
Mine acted very similar when my battery was bad.
Reactions: sharp
brushybarry
pikeville ky
just talked to tech at local honda shop. He says 100% its a oil pressure sensor. Told me there is 3 of them and if I want to fix it myself to change all 3, or bring it in and theyll hook it up and see which one is bad. They are several weeks behind on service work. I could take it to them and wait a few weeks and warranty may cover it, but Im just going to change all 3 myself. He said they have had 5-6 in with this issue and it has been a sensor on all with many having 2 bad. He was very confident so hopefully this will get it fixed. I got the sensors ordered and will update after getting them put in.
0860silverado
954
1,834
louisiana
Another possibility is a clutch update that was done incorrectly. There is an o-ring in the case that needs to be installed correctly. A few viewers had their machines returned to them after a clutch update with these symptoms. Turns out, when the oil is cold it is thick enough to keep pressure up. As the oil gets hot, it thins and gets by that part where the o-ring is supposed to be, causing a low oil pressure condition. But definitely check all your grounds and other electrical connections! Good luck and keep us posted.
2018GMC
2018GMC
174
356
AZ
Oh good lord. Mines going in for that and the other four fixes. I hope they know what they’re doing. Fingers crossed
I hear ya. My local dealer refused to do clutch update because the few they have done made it worse. I said don’t the new ones come with update? He said yes but they are not doing clutch update in their shop.
I’m going to eventually do the clutch update but prob drive 2hrs each way to a more experienced Honda only dealer that knows what they are doing ;-)
HondaTech
Not to stir up anything, but you need to call Honda and report them. They cannot refuse to a service update or warranty repairs.
Plus their just straight up lying about it being worse after the update.
0860silverado
954
1,834
louisiana
A friend of mine is a "tech" at my local dealer. Although he's a great guy and a good friend, I wouldn't trust him to work on anything more complex than my wheelbarrow. And he knows I feel that way about his work. It's all good but I think I'll research dealers within 300 miles who have done several and had no problems.
I had everything done at my local dealer, fingers crossed, and everything looks/runs good so far.....:cool:
