P1000 New to pioneer
W
WVMatthews1982
21
36
WV
We just recently bought a p1000-5... I had heard they were mechanically "noisy" due to the direct drive transmission. But ours seems to rattle something fierce. Shifts good and strong, but just so much chatter going on. No so much the engine but thendrive train specifically. Is this pretty typical?
Reactions: TripleB and Lady01
7,135
27,109
Welcome from Central Texas
Yes they are noisier than other belt style machines. Is the machine new? If so give it a little time, You will notice a difference after the first oil change. And then better after each one after that.
JUST MAKE SURE AND CHECK YOUR OIL LEVELS IN ENGINE,SUBTRANS,FRONT AND REAR DIFFS!
W
WVMatthews1982
21
36
WV
Thanks.
Yeah brand new. Well sort of. Sounds about right though. It just rolled over for its first service due... was told better off sending a certified dealer for the first couple to make sure fluids are flushed correctly and changed.
7,135
27,109
Thanks.
The oil changes are pretty straight forward. there is a great step by step writeup here on how to do it. Also i have had 3 of these machines and have not had a no problems with valve adjustments.
I cant stress enough to learn the correct way to check oil levels in this machine!!!! Check them yourself before you leave the dealership!!!!! Don't ask how i know!!!
W
WVMatthews1982
21
36
WV
What do u mean by you have had 3 of these machines and have not had a no problem with valve adjustments?
Stateboy
Stateboy
298
1,711
Wolverine, MI
Greetings from Northern Michigan. I'll have mine in late June. I'll be climbing on and under it to check those oil levels and rattles before leaving the dealership.
Sent from my SM-N960U using Tapatalk
105,177
Welcome from
Another Michigander!
what they all said!
BTW...PICS OR IT DIDNT HAPPEN!
Enigma
Enigma
East Tennessee Mudder
366
838
Rocky Top
Welcome from Rocky Top (TN). Honda SXS Club can help you with the right way to make your fluid checks and changes and it will cost you a hell of lot less than at the dealers.
208,011
HOW?
  • Haha
Reactions: Lady01 and JenElio
208,011
WELCOME from NW Arkansas!
K
Kelldog
117
I am a new owner. I just follow the owners manual. i dont beleive there is some hidden secrets on this
Reactions: Lady01
Wellzy
Wellzy
269
898
SW Wisconsin
Welcome from Wisco!
Oil changes are messy, but easy to do step by step and you save big time. Drain two holes, change two filters, fill.
Reactions: Lady01
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Welcome from Illinois good luck with the dealer.
Reactions: Lady01
