P1000 Newbie Questions
Jbird
Jbird
392
475
Mena, AR
I plan to follow my friend Cummingpusher's advice and have my Honda dealer perform the first service on my P1K5 but for subsequent oil changes I need to know what you guys are using at home to get these things up off the ground where you can work on them. I would also like to know where you are attaching your ratchet straps on the unit for strapping the unit to your trailers for transporting. Thanks for your ideas.
N
Nightcrawler
103
229
Portland, OR
The best way to strap down is a tire net. This is very secure and you are not putting any load on the suspension. In the Honda manual, I believe the just tell you to strap it to the front bumper.
Tirenet
The cheapest ramps you are ever going to get:
81hOzc2IGnL SL256
Go to your local Home Depot/lumber store and get 2 off grade 2"x8"x14' boards for a couple bucks each. They usually even cut them for you for free. Each one will make 2 ramps.
33"/27"/21"/2.5"
283,558
I don't lift mine at all to change the fluids, everything is pretty accessible.
I made an oil change guide here:P1000 - Honda Pioneer 1000 Oil Change Guide!
Useful service facts: P1000 - Pioneer 1000 3/5 Usefull Service Facts
When I transport mine I tie it down like this:
TD Front
TD Back
Hope this helps.
perry
perry
191
168
South Dakota
33"/27"/21"/2.5"
Where did you get the blue tire straps looks good.
ghost
ghost
993
1,874
BC
I like to have mine off the ground when servicing.
There are couple places you can hook into the frame for towing but I like those tire nets.
Ramp
Jbird
Jbird
392
475
Mena, AR
So would a couple of the metal car ramps from autozone make the drain plugs and filters easy to get to for servicing?
Absolutely. Do you have a Harbor Frieght close they would be cheaper. Maybe Walmart? But ramps would make it easier just diff lock driving up and no problems. @JACKAL made it easy to follow the steps and follow it to a tee and you'll be good. If you don't bring it in for first scheduled MAKE SURE YOU KEEP RECIEPTS! If you buy from a dealer buy under your name and they keep it for 5 years. Lay lots of rags under the filters when taking out to avoid a big mess
Jbird
Jbird
392
475
Mena, AR
Why diff lock driving up? I plan to take it to a Honda Dealer here in Arkansas that is 67 miles away instead of 235 miles one way where my son purchased it. I'll keep the receipts in our file box should I ever need to verify the first service. I also plan to buy the oil, filters, lubes, gaskets, crush washers, and O rings to have on hand for the next service or should I have to change the oil unexpectedly. Who is the best source for all these items?
It won't slip. In two wheel on the steel it may. We are hard core eBay it's always cheaper then local
Reactions: sharp and Jbird
