Talon Noise while under load
My R is chattering bad thought it was valves or trans BUT thinks to this thread it is for a fact my driveshaft, I took the hood off and reached down and the driveshaft is real loose.
Phuckity phuck, that’s not good. Please let us know what this is when you confirm...🤔
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Picked it up Saturday and that was it. Sounds like it should now. no more annoying noise.
Mine has same symptoms but I don’t feel any slack. Your slack was in the u joint caps?
Sawpilot
Sawpilot
57
151
West Virginia
barnwoodbuilds.com
Yes the universal joints, the caps get loose inside the yoke I welded Washers over my new drive shaft to keep the caps from moving, I also put a snorkel on mine with a KN filter and dry bag to keep my factory filter clean... works great
FFB1A52A A7F0 46E5 8B2F 2CA7AFF9C79E BAD8168D 7A51 4ACC BA3D E0C180A24E04 9BB22D6A FD50 4D4A ABCC 9425FA7EB01D
Doogle
Doogle
197
275
Surprise,Az Cincinnati,OH
Good evening everyone. I'm new to the group. I'm experiencing this same issue with a 2020 Talon 1000r I never heard or maybe noticed this chatter, until I just installed new tires. I just took it out today and really noticed the noise. I'm glad to hear its just a driveshaft issue. I'll remove mine to make sure that's my issue before ordering. I have 940 miles on mine is there anything else everyone is seeing as a warning for other issues?
Sorry nobody responded to you a year ago. I just read this and giving a link that would help, if you haven't seen it yet.
IDIOT
IDIOT
280
755
Kingman, Az.
My 2019 Talon-X Turbo has more of a rattle that seems to be coming from behind the passenger seat so I think it's a different issue. It's almost like an exhaust shield rattle. It's most noticeable when slowly climbing a hill though it also does it some during normal acceleration on level ground. I've checked the Turbo support bracket but that is tight. I've tried putting clamps around the shields to prevent rattling but it didn't make any difference. Has anyone else have this issue?
This is what may be rattling on yours.........
IMG 5985
Reactions: CID
Hometeam
Hometeam
1,025
4,326
Normal, IL
It’s driveshaft I just replaced mine with the new aftermarket driveshaft Erin Early makes.
Is that driveshaft noticeably quieter? I know it's a lot stronger. Not that I think they are really loud to start with, just curious if you can notice it over stock. Thanks
Reactions: Smittyp
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Yes no chatter that everyone has experienced. The chatter is when you are at lower rpm and higher gear. On black top or dirt road you will notice the chatter the most.
prostreet66mustang
prostreet66mustang
Oro Valley (Tucson) Az
Ya check the drive line and get out the welder and spot weld the caps. A must if you work it hard. And check the three front diff. bolts. I had one that came that was there but not tight?
