Have a related question in to joeymt33 if oil change freqency can be extended when using Synthetic oil. Anyone else already know a recommendation? Researching this thread. P1000 - Full synthetic oil
Don't know the official recommendation but I change it once a year, every spring with Royal Purple.
Most guys will change the oil filter with every oil change.How about the oil filter, how often do you change it?
Agreed, always change the oil filter with the oil.Most guys will change the oil filter with every oil change.
Trigger...does this mean you changed the filter once a year?Exactly what I do, with any oil change.
Steve00 the wrench will come on at 100 hours or 600 miles which ever comes first. The hour time starts when you turn the ignition switch on and off when you turn it off. If you forget to turn it off as I did, two times, the wrench will come on not to mention the battery going dead. Why Honda did this I have no idea. You would think the hour time would be engine run time not switch on time.Does the wrench only appear on the display in 1st and 2nd initial oil change intervals or will it pop up every 600 miles or so, or do I need to keep track of the miles everytime I need an oil change.... is it every 400 miles or 600?
