There has been a lot of talk about oil lately and some preferences about brands, weight, etc. I had looked deeply into oil research a few years back and book marked my searches. Copied and pasted here is some great info that is a must read. Pay attention to the part where you find out that Mobile 1 IS NOT A TRUE SYNTHETIC!
What does the SAE Viscosity rating on your Motoroil bottle mean?
Most of the time when viscosity is explained words are used that are too technical for the average person to quickly grasp. This leaves them still wondering what the viscosity numbers really mean on a bottle of motor oil. Simply put, viscosity is the oil's resistance to flow or, for the layman, an oil's speed of flow as measured through a device known as a viscometer. The thicker (higher viscosity) of an oil, the slower it will flow. You will see oil viscosity measurement in lube articles stated in kinematic (kv) and absolute (cSt) terms. These are translated into the easier to understand SAE viscosity numbers you see on an oil bottle.
OK . . .What does a 5W-30 do that an SAE 30 won't?
When you see a W on a viscosity rating it means that this oil viscosity has been tested at a Colder temperature. The numbers without the W are all tested at 210° F or 100° C which is considered an approximation of engine operating temperature. In other words, a SAE 30 motor oil is the same viscosity as a 10w-30 or 5W-30 at 210° (100° C). The difference is when the viscosity is tested at a much colder temperature. For example, a 5W-30 motor oil performs like a SAE 5 motor oil would perform at the cold temperature specified, but still has the SAE 30 viscosity at 210° F (100° C) which is engine operating temperature. This allows the engine to get quick oil flow when it is started cold verses dry running until lubricant either warms up sufficiently or is finally forced through the engine oil system. The advantages of a low W viscosity number is obvious. The quicker the oil flows cold, the less dry running. Less dry running means much less engine wear.
Obviously, cold temperature or W ratings are tested differently than regular SAE viscosity ratings. Simply put, these tests are done with a different temperature system. There is a scale for the W, or winter viscosity grades and, depending on which grade is selected, testing is done at different temperatures.
Basically to determine non-winter grade viscosity using a viscometer a measured amount of oil at 100° C is allowed to flow through an orifice and timed. Using a table they determine SAE viscosity based on different ranges. Thicker or heavy viscosity oils will take longer to flow through the orifice in the viscometer and end up in higher number ranges such as SAE 50 or SAE 60 for example. If an oil flows through faster being thinner/lighter then it will wind up in a low number range such as SAE 10 or SAE 20 for example. Occasionally it is possible for an oil to barely fall into one viscosity range. For example, an oil is barely an SAE 30 having a time that puts it on the very low side. Then another oil is timed to be an SAE 20 on the high side not quite breaking into the SAE 30 numbers. Technically speaking these oils will be close to the same viscosity even though one is an SAE 20 and the other an SAE 30. But you have to draw the line somewhere and that's how the SAE system is designed. Another system takes more accurate numbers into account known as cSt abbreviated for centistokes. You'll see these numbers used often for industrial lubricants such as compressor or hydraulic oils. The table at the right, SAE Viscosity Chart (High Temp), shows the equivalents for cSt and SAE viscosity numbers. You'll see the ranges for cSt compared to SAE numbers. An oil that is 9.2 cSt will be nearly the same viscosity as an oil that is 9.3 cSt, yet one is an SAE 20 and the other is an SAE 30. This is why the cSt centistokes numbers more accurately show oil viscosity.
Now if you look at the table labeled Winter or "W" Grades, you can get valuable information on how the W or winter grade viscosities are measured. Basically, as shown by the chart, when the oil is reduced to a colder temperature it is measured for performance factors. If it performs like a SAE 0 motor oil at the colder temperature, then it will receive the SAE 0W viscosity grade. Consequently, if the motor oil performs like a SAE 20 motor oil at the reduced temperatures (the scale varies - see the chart), then it will be a SAE 20W motor oil.
If a motor oil passes the cold temperature or W (winter grade) specification for a SAE 15W and at 210° F (100° C) flows through the viscometer like a SAE 40 motor oil, then the label will read 15W-40. Getting the picture? Consequently, if the motor oil performs like a SAE 5 motor oil on the reduced temperature scale and flows like a SAE 20 at 210° F (100° C), then this motor oil's label will read 5W-20. And so forth and so on!
I can't tell you how many times I have heard someone, usually an auto mechanic, say that they wouldn't use a 5W-30 motor oil because it is, "Too thin." Then they may use a 10W-30 or SAE 30 motor oil. At engine operating temperatures these oils are the same. The only time the 5W-30 oil is "thin" is at cold start up conditions where you need it to be "thin."
What about synthetic motor oils? Do they need Viscosity Additives?
Group IV (4) and Group V (5) base oil (synthetics) are chemically made from uniform molecules with no paraffin and generally don't need Viscosity Additives. However, in recent years Group III (3) based oils have been labeled "synthetic" through a legal loophole. These are petroleum based Group II (2) oils that have had the sulfur refined out making them more pure and longer lasting. Group III (3) "synthetic" motor oils must employ Viscosity Additives being petroleum based.
Group V (5) based synthetics are usually not compatible with petroleum or petroleum fuels and have poor seal swell. These are used for air compressors, hydraulics, etc. It's the Group IV (4) PAO based synthetics that make the best motor oils. They are compatible with petroleum based oils and fuels plus they have better seal swell than petroleum. Typically PAO based motor oils use no Viscosity Index additives yet pass the multi-grade viscosity requirements as a straight weight! This makes them ideal under a greater temperature range. One advantage of not having to employ Viscosity Improving additives is having a more pure undiluted lubricant that can be loaded with more longevity and performance additives to keep the oil cleaner longer with better mileage/horsepower.
How do I know what motor oil is a Group IV (4) based PAO synthetic motor oil?
As more and more large oil companies switched their "synthetic" motor oils to the less expensive/more profitable Group III (3) base stocks it has become much easier to identify which are PAO based true synthetic. Of the large oil companies, only Mobil 1 Extended Performance, as of this writing (12-16-2012), is still a PAO based true synthetic. The rest, including regular Mobil 1 and Castrol Edge have switched to the cheaper/more profitable Group III (3) petroleum based "synthetic" motor oil. AMSOIL Synthetic Motor Oils are PAO based true synthetic motor oils with the exception of the short oil drain OE and XL synthetic motor oils sold at some Auto Parts Stores and Quick Oil Change Centers. This leaves more than 20 PAO based true synthetic motor oils manufactured and marketed by AMSOIL with only a few Group III (3) based synthetic motor oils identified by the "OE" and "XL" product name.
So as you can see, the average performance of motor oils can be affected by how they change during their service life. Multi grade petroleum can lose viscosity and thin causing accelerated wear as the VI additives shear back. Straight weight petroleum (i.e. SAE 30, SAE 40) thicken a lot as they cool meaning longer time before lubricant reaches critical parts on cold starts, but have no VI additives so they resists thinning. However, they can degrade and thicken as heat and by products of combustion affect the unsaturated chemistry. Group III (3) synthetics resists this degradation much better, but being petroleum based employ some VI additives which is a negative and typically don't have as good performance in the volatility viscosity retention areas. Only the Group IV (4) PAO base synthetics have the saturated chemistry to resist degrading when exposed to the by products of combustion and heat, plus typically employ no VI additives making them very thermally stable for longer periods. For this reason the Group IV (4) synthetics maintain peak mileage and power throughout their service life.
For more to read and to see the tables, visit this site:
Motor Oil Viscosity Grades Explained in Layman's Terms
