OIL Question
HappyHonda
HappyHonda
50
34
I need to add some oil to my Pioneer, I know the manual says to use 10w-30, but I have some 10w-40 leftover from when I had a 400ex. If I just wanted to add a little, would it be fine to use the 10w-40 or should I just go get 10w-30? Thanks
Happy
39,079
I would not be worried about it as long as both oils are from the same manufacture.
Joe
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Motorcycle oil is best because of the wet clutch but doesn't have to be just make sure it not energy conservation because there are lubrication in there that will cause havoc on your clutch and DEFINITELY NO ADDERS like ohanacreek said I run Mobil 1 full syn 10w30 in everything even my crf250l and couldn't tell a difference from when I ran amsul or royal purple motorcycle
HappyHonda
HappyHonda
50
34
thanks everyone! I called the dealership I got mine from and they said its fine. I had some GN4 10w40 leftover from when I had a quad, so I think Its fine to use if I'm just topping it off. Regardless though, I like to be extra safe when it comes to these things, I'll be picking up some GN4 10w30 today or tomorrow.
Happy
Test - Grid
