P1000 Oil strainer / oil pan bolt torque specs?
Hondoman
Hondoman
727
1,697
Texas
Anyone know what the torque spec is for the oil pan bolts?
Reactions: sharp
Hondoman
Hondoman
727
1,697
Texas
@HondaTech can you answer this?
Hondoman
Hondoman
727
1,697
Texas
63,893
Don't seem to be listed. Fd807f93e3a180aa35a0deb3479bfd44290267ff1d12f1794cd0a5b844812c49
Reactions: Hondoman
lee
lee
Village Idiot
2,342
13,147
Springfield Ohio
Hey @Hondasxs I think the actual torque values are listed in the front of the manual.
Section 1.
There is a long list of special torques but I didn't see the oil pan listed there.
So then you refer to the standard torques.
Page 1-11
Upload 2017 10 22 17 10 1
I'm guessing it's a 6mm flange bolt - 6mm is the dia of the threaded portion.
(sorry I didn't run out to the barn and crawl underneath to look - too busy watching Honda choke (again) at the Formula 1 GP in Austin Texas)
it will have a 8mm hex as listed above.
0.7 lbfXft
This torque is for a dry fastener.
If you have oil or grease on it you must reduce the torque or risk popping the head of the bolt off before reaching the torque.
So you can get out your 1/4" drive torque wrench and clean each hole with brake cleaner or do it by feel.
Of course I only recommend one of those methods.
Reactions: Hondoman
