P1000 P-1000 Skid Plate
P
packer58
312
943
N. Cali
My 2021 P-1000 has the factory skid plate that basically covers the middle of the machine and I would like to add the skids that protect the floor boards, at one point I found a source for the two outer pieces but for some reason can't find em anymore.......anybody have a source for the two outer pieces ??
Thanks
115,308
Thanks
Not worth your money or time imo. That G string in middle there barley helps stop pea gravel in a garden. might as well have a pice of cardboard.
adding side skids to that will help but like pitting lipstick on a pig. why waist the time?
Just buy some upgraded full skids that really protect you from all sides. youll be glad you did In the long run.
Russ989
Russ989
22,641
147,241
^^^^This^^^^
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
I got the Tusk 3/8" UHMW. It's one of the less expensive ones out there that is still very effective for those of us that aren't hardcore rock bangers.
Mine just needs to protect from trail threats and rutted areas.
Rayger143
Rayger143
3,075
26,993
Winfield, BC Canada
You don’t have to be a hardcore rock banger to come down hard on a rock. It happens.
bumperm
bumperm
1,898
6,776
Gardnerville, NV
What type of hardware did you use for the install?
Ones I've seen, and I'm no expert, will used existing hardware or bolt holes where practical. In some other areas they use self-drilling self-tapping screws that go directly into the frame. My preference would be to use rivet nuts (sometimes called rivnuts) to install female threads in those areas. This has a couple of advantages over self tapping screws. Rivet nuts have better holding power and can easily be replaced if damaged. Rivet nut installation tools are reasonably priced.
Reactions: Robobrainiac
Spoonbill
Spoonbill
226
272
East TN
Thanks for the quick reply. I ll add that to my options
Bow4life
Bow4life
129
540
Minnesota
Like others have said, the factory one is garbage, almost an embarrassment on a 20k machine. Super ATV makes a good one. I'm planning to put that on mine. It's the UHMW type. Hes a vendor on here too, I think if you pm him he'll get you a little break on the price. Just my .02
SaltwaterSlick
224
946
Southeast Texas
Rivet nuts in conjunction to the factory threaded mounts also make it easier to remove and reinstall the skid plate. It is a good practice to remove the skid plate periodically to clean the debris that collects on top of it... It's good to remove the skid plate for oil changes to reduce, even eliminate the mess that oil changes make when done with the skid plate in place... Will save you money on oil rags/paper towels!! :p
Spoonbill
Spoonbill
226
272
East TN
The Rivet Nuts require their own stud and not the original OEM metric self threading screws , correct?? What screws are you using with the rivet nuts?
Reactions: Rayger143
Rayger143
Rayger143
3,075
26,993
Winfield, BC Canada
Rivet nuts come in different sizes. Just match the thread size and the length you need.
russknight
russknight
1,910
7,509
Perry Florida
Thanks
Ricochet Offroad.
brettc
brettc
84
294
53
Little Rock, AR & Crawford, CO
I'm curious, what does your factory skid look like? Is there some thin stamped steel skid on some models, or plastic or something?
