I just wanted to report back since I brought it into the dealer. So after the repair/recall work was completed, I took it out and found for the most part it did just fine except for 2 small occasions were the machine just cut off for no reason. It was just turned off as if I turned the key to off and the only way I could restart it was to turn the key completely to the "off" position and then start it again. Like I said, this happened twice since I got it back from the dealer. Well, I took it back out the next day and it happened again but only this time it happened a lot more often. I would say for the 3+ hrs. I had it out, it turned off by itself about a dozen of times. I immediately contact the dealer yet once again, I'm starting to feel like I got a lemon here...so frustrated! So currently, it's back at the dealer again. Meanwhile, I've been doing some research on my issues and found that what may be causing this is the fuel injector plug connectors. Apparently, the wire on these (especially earlier models like mine 2016) connectors have a history of breaking and/or separating causing a faulty connection at the injector. So I'm curious if anyone of you guys have had this issue and also if not, would a weak or bad battery cause this same symptom. Thank you for any feed backs, I'll probably repost this on a new thread.
