P1000 P1k Cooling modifications
56,731
Wish the heater was an option here! With less than 10 days a year that the temps dip below 32° overnight, And normally 30+ days over 100°. The heater is out!.
Same here! Interested in seeing how Kilo's custom setup works out.
Reactions: CumminsPusher
RockRain
RockRain
48
101
UT
For the record I have just shy of 600 miles on mine and have never had any overheating issues. I took it out for its first trip and had a good time. Started on my dual battery setup and dropped a small screwdriver down the intake tube. Had to pull the seat out and get to it that way. When I pulled the seat off I found the clamps just dangling there, never got tightened. Glad I caught that early on. I had them do the update and I have been on a couple trips since then and it seems like it runs cooler because I haven't been able to get over 2 bars where before I had programming it would hit 3 occasionally.
Reactions: Tramguage1
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
I found out the fan on the Talon comes on at 222 degs and off at 220 degs. There is also a maximum time on of 10 min, not sure how that works though. I imagine the Pioneer is similar.
7,141
27,154
So if it cant achieve 220 in 10 minutes time you will never catch up!!!!!!!
Vikes79
Vikes79
SKOL!
10,884
105,590
South Dakota
  2. Talon X4 LV
Have you considered changing the antifreeze ratio in your coolant?
Glycol is not as good of carrier of heat as is straight water.
I’m not suggesting eliminating antifreeze, just adjusting the percentage. Right now I believe the factory mix is rated for -40 or some crazy low number.
At your temps a 25% mix (75% water) would be more than adequate freeze protection and still provide corrosion protection. Just have to be careful and watch the thermometer.
Reactions: Haldog77 and JTW
HappyCamper
59
103
Wyo
After reading this thread, the question I have is what is this "burping" you're all talking about nd how do ya do it?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Raise the front end, i.e. park on a hill, remove the radiator cap and let it run for 15 - 20min. If there is air in the system it can start blowing it out so be careful. Keep topping off the radiator until it stops. Run it around some, let it cool off and recheck on level ground. Mine was blowing coolant 6'+ in the air after about 10 min of waiting.
HappyCamper
59
103
Wyo
Thanks for the reply. I'll give it a go.
Reactions: TripleB
BigOL3
BigOL3
2,994
8,918
Oh overheating problems huh, well let me tell you I have fought and fought these problems over the last 4 years. Some things that have helped the vent I cut in the bumper helps a lot until you encounter a lot if mud, a real coil cleaner that makes your skin feel like it’s melting also is helpful to use sparingly, the mostly helpful so far is having a fan override it’s helps tremendously and for most people will alleviate most the troubles.
The facts are under optimal operating parameters the radiator is just enough, but if you add such outside factors as, high elevation, dirt in radiator, abnormally high temperature ambient, aftermarket bumpers that disturb air flow, IGR or ecu that cause higher RPMs then the radiator can not keep up.
The size of the radiator is to small, the fan is to small and underpowered, the shroud isn’t much of a shroud and the fan algorithm often times kicks the fan on to late to combat the heat.
I am having a radiator made at this time that will be much larger, much easier to clean with a shroud and significantly more powerful spal fan because I am tired of looking at bars instead of riding. That being said for a normal user if you could just add a better fan, or a real shroud in conjunction with the over ride you would probably be fine.
There is defiantly an art to burping them as well take the cap off wait awhile the moment you look is generally when the damn thing will spew radiator fluid 6 foot in the air. The weird part is a lot of times what comes out isn’t even that hot
(Thankfully cause I have got a face full twice) cause the top part has cooled off but the bottom is still boiling.
As soon as that radiator combo becomes available I will release more I about it.
Did you get the new system installed? If so, what was the outcome?
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,601
Oshkosh, Wi
I know @Kilo427 is working with someone on a radiator/shroud mod. I also will be swapping out my fan for one of these.2016-2019 HONDA PIONEER 1000 SPAL HIGH PERFORMANCE COOLING FAN 19030-HL4-A01 | eBay. Also I think this is a must do on all P1ks Cooling Fan Override for Honda Pioneer 1000 models..Its just to inexpensive a mod not to do.
Did you install the Spal fan? How did it work? I tried contacting UPI and they did not get back to me. I'm curious what the difference in air flow is between this fan and stock
Reactions: Pilgrim and BigOL3
7,141
27,154
No sir I havent jumped in that project yet. Life happens and I just havent had time to get to it yet. Now it's almost TO time.😔
Pilgrim
Pilgrim
559
4,246
Oklahoma City
Well sports fans..... I installed the fan override and then haven’t put many hours on the machine.....
took it to Colorado last week and on a easy but steady twenty minute uphill at less than 40 degree ambient temp.... my light came on.... didn’t boil over and I was at the top of the climb so I don’t know if it would have or not.....
I was hoping to go back to this thread and see where someone had found a proper radiator install or some thing to fix it......
I am about to decide my windshield washer jug and pump is the best fix.....
I purchased a Wolverine this spring and it has an actual temperature readout.... instead of three bars and a light....
it runs hotter than I would have thought but no red light or overheat......does Honda just have too low a setting on their red light??
has anyone tried a higher pressure Radiator cap?..
I still stick with my opinion of marginal system at best and not up to typical Honda engineering standards......
Marginal cooling system is 100% accurate!!
G
golfer1
117
269
Alabama
Has anyone tried a supplement radiator like the ones you see in front of you car or truck radiator? Seems it would add more cooling surface and increase coolant amount.
HappyCamper
59
103
Wyo
? Never heard of a supplemental radiator.
HappyCamper
59
103
Wyo
A higher pressure radiator cap will do nothing for the heating problem. It just raises the temperature at which the coolant boils, the heat or, in this case the overheat, will still be there.
G
golfer1
117
269
Alabama
supplement radiator something like this. I know its a oil cooler but probably could be use with anti freeze as well. Look under second radiator cooler. Also summit racing has a oil cooler that could possible work. Tried to post a lin k but not smart enough.
