P500 p5 suspension
Chooglin
So these bolt to existing mounts then are welded into place? And are for the fronts only? Why the milled or textured finish on one side of the plates?
Good work guys, thanks for sharing and looking forward to results!
j
Yes they are bolted and welded !
The mounts in the above pic are for the rear. I also made some for the front (posted a few pages back)
The milled area is so the existing mount will fit into the new mount
chrisC
chrisC
138
259
Newfoundland, Canada
I picked up the first set of mounts from the machine shop tonight.I will get them mounted and welded on tomorrow.
View attachment 25782 View attachment 25783
I am still waiting for my new shocks to ship , so I will need to wait to take it for a ride until they get hear.
@solrus I ask him to make two sets but for whatever reason , he only made one. he will be making a second set at the beginning of the week. I will get them shipped to you as soon as he finishes them !
Nice job on the relief on the plates! Tidier than using spacers between the shock and mount. CNC mills are great. Was it cut with laser or waterjet?
Chooglin
He was actually going to use a CNC plasma cutter but the material was to thick (.250) for his unit. He ended up cutting the entire thing on the CNC mill !
We are going to be taking them to a shop and have the profile of the mounts cut with a CNC laser cutter and then he will mill the relief in them.This should also cut down the cost of them !
Chooglin
@chrisC do you have some machining background ? you seem to have a good understanding of why I made them the way I did !
Chooglin
Mounts are welded on , now all I need are some longer bolts and some damn shocks to mount to them !!!
20161107 175851 20161107 175458 20161107 175410 20161107 173223
solrus
solrus
1,629
2,511
Montana
Common , cancel them from that seller, I got mine in 3 days, and cheaper also , so not too late to get 429 or 425 HD but cheaper
solrus
solrus
1,629
2,511
Montana
One more question, please measure the distance between wheel and mount. I'm just not sure if I should be proactive and get 1" spacers.
Chooglin
You need to be proactive , it would be real close without the 1.00" spacers !
It mite work without them and I can remove mine and check it if you want me to !
Chooglin
@solrus would you mind posting a link again to where you bought yours , so I can order them , should I cancel my order
solrus
solrus
1,629
2,511
Montana
Please take one off , on one side , if I need them , then I need an advice what company I should buy from.
solrus
solrus
1,629
2,511
Montana
Cancel, tonight if possible online, confirm yesterday, get 429 and enjoy your ride this weekend !!! :)))
425 HD or standard OOS - Schizer!!!! pardon my German!!!!!
http://www.phatperformanceparts.com/ProductDetails.asp?ProductCode=PROG-425&CartID=
BUT!! 429-1003 FITS Rhino 450 (06-09) / 660 (04-07) / 700 (08-13) Rear - 15.5 H.D. IN STOCK!!!
I think its a sigh from above to get 429!!!
Progressive Suspension 429 Series Shocks - PROG-429 - Phat Performance Parts
solrus
solrus
1,629
2,511
Montana
But Super ATV is 1.5". Ok waiting for your test without spacers and if negative then what optimal spacer thickness I need.
Chooglin
It is a NO GO without spacers !!!
20161108 170408
These are the flange bolts and flange nuts I bought tonight , you will need 4 of each (purchased at home depot).20161108 175135 20161108 175308
You also will need 4 lock washers and 2 1.500" long spacer for the 2 bolts that go in the stock mount !!!
Reactions: solrus
