![JWB](/data/avatars/m/5/5868.jpg?1530844228)
Yes, I'm going to make them isolated, or paired side to side with separate air valves, and I could, with the set up I'm building have all the shocks seeing each other- not sure if that would ever be an advantage.... I'm still waiting for all my tubing and fittings to show up, but I'll take pictures as I put it all together. If you're asking what the outside diameter of the actual shock is, I don't know, and everything is at the shop where I work, but I can tell you they are a lot smaller than the stockers, and way lighter. As far as mounting, I haven't actually started measuring yet, but for the upper mounts, I think I will carefully remove the existing mounts completely, and either buy, or fabricate a 'u' channel that will 'saddle' the frame rail, and weld my mounts to that. It just seems that it would be easier to get everything located exactly how I want it, and not risk weakening the frame If I screwed up the mounts and had to remove and re-weld a couple times. Screwing up is pretty normal for me....are you going to put a switch to let the shocks see each other and be isolated depending on the terrain. i am going to try this mod if for no other reason than it is so inexpensive compared to a variable rate change up, that you can afford to bring spare shocks to install if one fails i am going to do the double up mod you have been talking about. the front looks fairly simple the back might have some clearance issues unless you move the upper mount to the outside of the frame. by the way what it the diameter of the upper side of the shock the gabriel specs dont say.
EDIT 8/3/17 JWB- subsequently found that no welding was needed, and the shocks are a near 'bolt in'. See the remaining posts. Shocks need to be doubled on each wheel, as singles require too much pressure, and may fail quickly
