So i came out this morning with full intentions of cutting farther back into my frame and finishing my frame mod to clear the bigger tires and i got side tracked. I have been thinking of moving the p500 radiator back from the stock location to the next crossbar behind it. So i jumped in. I took off the hoses, drained the radiator, separated the radiator from the fan and shroud guard. I took this opportunity to clean the radiator fins out real good and then bolted the fan back on. Moved it to the crossbar farther back under the hood and eyeballed the best location. I drilled and tapped holes in the rear crossbar and made a new bracket coming off of the metal firewall to suppory the bottom of the radiator. I used the rubber gromets from the stock radiator lower mount in the new radiator rubber mount. Welded new radiator lower mount to firewall and painted it black. Installed gromets and mounted radiator in new location. The top radiator hose just needs to be extended about 6" and the bottom hose needs to be rerouted all together. Im going to have to take a hole saw and cut a hole between the gas and brake pedal in the firewall and run the lower radiator hose through the firewall, between the gas and brake pedals, down the inside of the firewall and through the floor. Of course the hose will get a metal protective cover and will not interfere with the pedals or my feet at all. I may actually end up cutting a piece of pipe in half lengthwise and using half of it for the cover and welding little tabs on the side of the pipe so i can rivet or bolt it to the wall behind the pedals. Im done messing with it for today. I will get back on it tomorrow morning and post more pics and explain what i did. So far ive got about 2 or 3 hours messing with this little mod so far. There is a before and after mount pics and a few of the lower bracket. There is about an inch or so clearance under the hood to the radiator cap. This mod moves the radiator back about 8 1/2" and up about 6". Kinda making it less vulnerable to sticks and stuff, and i can see it will definetly make it easier to clean mud out of the fins, but then again, maybe there will be less to clean out now anyway now that its a little higher. Hope you enjoy.
