P500 P500's a real pita in the cold
Buford
Buford
362
586
U.S.A.
A real annoyance to me is the throttle cut out for shifting until they are warmed up. Seems to be especially bad on the new auto.
Everytime you take off in first/low, then try to shift to second, the throttle cut out makes the engine stall. Start it up and take off, try to shift, same thing again. So then a person has to stay in the same gear until it warms up a little.
The ES on the 4 wheelers don't have that cut out and shift just fine when they are cold.
Hopefully somebody will come up with a way to do away with it.
rocmar
rocmar
4,741
5,775
4 CORNERS
Mines fine in the cold
.....but I Usally start it
up....while gathering
my ramps....other
bulls***...
I'm gonna try just jumping
in & see wat happens
Reactions: joeymt33
maddmax
257
231
Clarksdale Ms.
my ramps....other
bulls***...
I'll check mine in the morning, it'll be 19 here with windchill around 12*
Reactions: Dp5hunter
Shadesmn
Shadesmn
505
959
Ramsey, MN
I can confirm they are very cold blooded as far as that shift from L to 2 at first in the cold...and yes, huge pita.... once you get it to shift then its fine, but the cutout is annoying when it wont shift, never had that issue on our rancher es. But like @Buford said they didnt have the cutout on them.
Reactions: rocmar
Shadesmn
Shadesmn
505
959
Ramsey, MN
Start in 2nd. I seldom start in 1st, unless steep hill or otherwise need to go that slow. FWIW: I have 26" tires.
Trouble is you have to remember to leave it in 2 when you park it then. Otherwise you still need to get past L...
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I always leave mine in neutral in the garage and roll it out into the driveway to start. I do start it and let it run for a while, but always shift to 2nd before moving. Are you saying that stationary, when cold, you can't shift past 1st? If so, sorry, I haven't seen that or been cold enough.
Shadesmn
Shadesmn
505
959
Ramsey, MN
I'd have to go out and confirm if it will go right to 2 before moving or not. But i think it will only shift if you move it, so you need to go into L and move a bit or it wont actually change gears. It makes a click like it wants to shift, they just dont actually upshift when cold. I mean real cold. I think its better when its warm out. Its currently 20° with a windchill of 9°, so im in no hurry to play outside right now since i dont have snow to plow:D
Reactions: rocmar
rocmar
rocmar
4,741
5,775
4 CORNERS
I let it run...
to warm up
while I get all
my s*** into
one bag. ....then
think hard of where
I put the bag
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I just went out in the garage and tried this. Turned the key to on, did not start it, put foot on brake and was able to shift into 1st and 2nd and back down to neutral. It is snowing here, but probably 45 degrees in the garage.
Reactions: Shadesmn
Shadesmn
Shadesmn
505
959
Ramsey, MN
So it changed gears then? Or did it just show 2 on the display? Not trying to be cynical, just wondering. It sounds like i will be pushing some snow on Saturday so ill check mine then.
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Yes, I heard the normal gearcase clunk on shift. I'm sure if I started it would be in 2nd. If it didn't shift I would see a "-" on the shift display.
Reactions: rocmar and Shadesmn
160,066
Yeah, I never start in L under normal conditions. I park it in neutral and have never had a problem shifting up to 2nd.
Haven't ran it when it's been real cold out though.
Shadesmn
Shadesmn
505
959
Ramsey, MN
Cool. I'll have to check mine. I just know if i do go to L first, she puts up a fight going to 2 from there. Cant recall if going right to 2 has ever worked...i probably have done it and dont even realize. Thats what i usually did with our rancher, so i may do it out of habit when its warm out...
Reactions: rocmar
Shadesmn
Shadesmn
505
959
Ramsey, MN
Pretty sure i start in 2 when its warm and im riding. Lately I've only been using it on the driveway and going slow to keep the snow where i want it. Usually dont go past L when pushing just to keep momentum but not lose traction by trying to go too fast and push too much at the same time.:). Plus my driveway is pretty small so i need to use as much seat time as i can to play in the snow;)
Reactions: trigger and rocmar
rocmar
rocmar
4,741
5,775
4 CORNERS
P5 is cold blooded
on the shifting...when
cold...just how it goes
give it a minute. ...you'll
be fine
Reactions: MrP500
rocmar
rocmar
4,741
5,775
4 CORNERS
Hey shade
....get a vid of
that BadAss p5
pushing snow with
that 66
