P500 P520 BED, will it fit the P500
Recarga
15
79
Dallas Tx
hello
sorry if this has already been asked i did a little searching but could not find if the new P520 cargo bed will be able to be fitted into the P500?
Reactions: J80
11,310
84,010
It would likely take some fabrication like what @906UP and @sthomp54 did below for Umax dump beds. The pivot points and dump catch on the 520 bed looks similar to @Flinterboy247 photos of his 520 bed.
Flinterboy247 520 bed pics.
Umax box fabricated mount options below.
88646382 526E 4054 AD6F 196EE5B1BECD 33501BB2 4350 4B45 BB7B 005DE955E843 B166E522 64C0 4216 8122 26F43FEC7277
P
pappyo
593
2,377
Check post ( New Member from Onterio Canada ) meaasge 7# picture far right.
It shows how Honda attached the box ( tubing slips into rear of frame ) hence added length of P520.
I used that same method to attach my extended rear mud guards for track system.
Going to request a better picture of that area.
20201114 111452
20201114 111440
906UP
906UP
12,997
121,150
da Yoop
Just for Sh#ts & Giggles I priced out the bed and all required parts to put one on a P5, it was close to $2K and I probably missed a few items. That did not include the new airbox that would be required along with a new exhaust to make room for the airbox so add another $800-900. Then you would need to modify the frame by removing the "post mounts" for the current rack, moving or adding the crossbar and extending the rear tubes. So in a short answer, NO.....not really.
11,310
84,010
Excellent info, thanks for the research.
Makes $150 for a aluminum vs plastic bed even better. I might just put my extra Umax box on Craigslist.
906UP
906UP
12,997
121,150
da Yoop
I ended up selling mine with the frame I built to a friend who was going to put it on his Dad's new P5. I didn't use it as much as I thought I would and it made it kinda squirrelly for Lil'906UP to trail ride.
L
Lonsinger01
Walhonding, Ohio
Going to request a better picture of that area.View attachment 247702View attachment 247703
Where did you get the rear fender extensions?
