Paddle shifters not working
bigcountry4x4
19
47
US
When I put my 2016 p1k5 deluxe into manual mode I can upshift with the paddle but it won't downshift. Tried different speeds and it does eventually shift on its own down when it's almost to a stop. It won't let the engine die. My question is, is there an adjustment on the paddle that could be out? Or is it electronic? Thanks for the info guys. Only mods are roof and windshield, and Honda's water ingestion fix.
Sent from my SAMSUNG-SM-G890A using Tapatalk
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
the shifters are elecronic have you tried disconnecting the battery for 20 min and re connecting it to see if it resets the computer
Reactions: CumminsPusher
bigcountry4x4
19
47
US
Did not try disconnecting the battery yet. I will give that a shot tomorrow.
I don't recall a click when trying to use the paddle either
Reactions: Plumber32
W
Wesley
Jackson, Al
Did you ever resolve this issue? I am having this exact problem.
tbaker
355
595
NW. Georgia
Mine was doing the same thing I took the bolt out that holds the paddle shifter on it was not straight in the hole I put the bolt back in and got everything to line and bam it works perfect
W
Wesley
Jackson, Al
Yeah I've taken mine apart everything seems to be working mechanically the paddle is physically toggling the switch but it's just not shifting.
bigcountry4x4
19
47
US
Yea sorry. The paddle wasn't making contact with the toggle. A little fine tuning got it working
Sent from my SAMSUNG-SM-G891A using Tapatalk
Reactions: JTW
W
Wesley
Jackson, Al
I took the cover off again and re verified I am toggling the switch. I even removed switch and toggled it with my finger while driving to see if maybe the paddle was not pushing down on it enough(still nothing.)
I am guessing that the switch has failed. I called the dealer and of course they have never heard of such issue and they want me to bring it in but they are an hour away. I'd have to leave it and come back another day to pick it up which would be a bigger pain in the *** than not being able to manually downshift.
2018GMC
2018GMC
173
354
AZ
Any update on this?
My 2017 1000-5 deluxe will not downshift with - paddle in MT mode. Transmission works fine in auto mode and I can manually upshift + in manual mode.
W
Wesley
Jackson, Al
I haven't really done anymore troubleshooting since my last post. It still shifts flawlessly in auto mode and I can still manually up shift but can not down shift in any transmission mode. It's funny that you ask for an update because I was thinking about digging back in to it just yesterday. I have not been able to find a single thread where someone has had a faulty switch or wiring but that is what I previously narrowed it down to for the most part.
Keep me updated on what you do maybe we can help each other out.
13,349
64,930
I'd bet the arm came off the microswitch.
I think it is a relatively inexpensive harness to change.
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
might need to pull the steering wheel and check the eletrical connections
Reactions: Neohio
W
Wesley
Jackson, Al
A
Any update on this?
I want to say thank you for pressuring me in to getting to the bottom of my shifter issue. I found the problem and resolved it for the price of a couple of but connectors and a piece of wire both of which I already had on hand.
20190418 175743
It seems that I had an unwelcome visitor in my shop.
TripleB
TripleB
11,694
99,247
Caryville, Tennessee
A
I want to say thank you for pressuring me in to getting to the bottom of my shifter issue. I found the problem and resolved it for the price of a couple of but connectors and a piece of wire both of which I already had on hand.View attachment 123989 It seems that I had an unwelcome visitor in my shop.
Good deal!
A
An easy problem to fix once found.. I’ll take that EVERY time!
2018GMC
2018GMC
173
354
AZ
EE23CB4D FB6D 4371 A56F E6F609C5D451
A22E4D7B C104 4BEE 9982 E341EB72D53C
6AC00404 2B35 4E2E 9986 BD3C5039C0CD
858458BC 8017 4D8A 9B92 FF39B90CBAA1
I’ll blame mine on local dealer that installed heat product improvement campaign.
Wire was pulled out of plug. Stuck that back in. Still no downshift. Pulled front door and fender off. Found broken red wire and nick in other 2 wires where it splits from the main harness.
Had to disconnect a few other connections to get wire harness pulled out far enough on passenger side to be able to splice together.
Fixed!
Reactions: TripleB
2018GMC
2018GMC
173
354
AZ
Not sure how the wires got nicked where harness splits off but I bet the the red wire got pulled out of plug when heat improvement rubber was installed.
Now that I think of it, not sure the heat recall really did anything but cause my paddle shifters not to work!
Reactions: JTW
2018GMC
2018GMC
173
354
AZ
A
Glad yours got fixed! I spent the day with a few beers and tracking down where my problem was. Cheers
