P1000 Parking Brake?
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
Can anyone explain how the parking brake works on the P1K? Has anyone parked on a steep hill yet and had to leave it in park? Did the tranny bind up when you tried to take it back out of park? I've been hesitant to park mine on a steep hill...
Reactions: DGann
39,079
I really wish it had a hand brake. I did park on a steep hill as pictured below. It made a loud "bang" when I pulled it out of park.
1c416b1255bc0fb4370788ad05169c3a
Reactions: DGann
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
dang... I was afraid of that...
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I wonder if we could leave them in gear and then go to park when you get back in and have your foot on the brake? the way you're parked, leaving it in reverse should keep it from rolling backward, but I'm not sure with this superwankydine tranny they put in there...
Reactions: JACKAL
rcarroll
9
It will roll away very fast if you don't put in park
hondabob
1,161
4,537
Prescott Valley, AZ
Put the locker on and turn sharp to let the wheels bind then put it in part. I usually back up a bit. On my Polaris I added a parking brake.
Reactions: PioneerPete
P
PoolGuy444
11
17
Tell us more about this parking brake you added. I didn't know that was possible. I used the parking brake on my 700 all the time. I could do without the cupholder.
nbomar
nbomar
4,416
17,854
Springdale, AR
I had a pawlector parking brake on my Rzr. Someone could engineer one for this easily as well. I don't have the skills or machinery to do it.
Reactions: amc019
39,079
Yeah, I was thinking the same thing. My buddy told me about adding one to his rzr. Well, there's something else to add to the list.
Reactions: Hondasxs
amc019
amc019
480
592
Little Rock, Ar
Had a pawlector parking brake on my 1000XP and loved it, felt much better about towing the rig with it set. Wouldn't budge.All it was is a hook of sorts that would slide over by using one foot and grab the brake pedal when depressed with the other foot, and then press the brake again the hook was spring loaded so would disengage itself off the pedal. Kinda like an old tractor parking brake. However, the chances of a company making one for a Honda SXS are probably slim to none unfortunately.
nbomar
nbomar
4,416
17,854
Springdale, AR
I have a friend who is a machinist nd fabricator so if I could get the design on the selector, I could see if he wanted to adapt it to the Honda to sell. He told me he is looking for stuff like that to make and market for smaller markets.
Reactions: Hondasxs
Jack39
64
31
Wareham, MA (near cape cod)
How about a Mico brake lock? Either that or a heavy duty small diameter ball valve cut into the hydraulic brake line? I'm not sure of the schematics of the system, but if you could just get front or rear it would work.
Itsalljake
Itsalljake
141
50
Los Angeles
Still putting together the offer on mine but I'll really curious about the P Brake option. I'll be stopping on all kinds of hills. Did anybody figure out the braking mechanics ? Is it breaks and trans or does it just lock up the transmission? Had a thought, if there is a brake engagement, where does it take place in the shifter location? Again, not having one, seems like moving the shifter up would engage brakes and then moving it over locks up the trans. Possible vice versa. Why not add a spot for the shifter location for brakes only? Just a thought.
Itsalljake
Itsalljake
141
50
Los Angeles
Obviously a quick mod, while the salesman wasn't looking.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
The parking brake on the p1000 is some sort of stopper plate. It has one in the front and in the rear diff. It has an adjustment located in a metal box thats behind a removable panel in the floor.
7,141
27,151
Are the brakes on the P1000 hydrolic? If so a brake line lock would work. Electric selenoid would work.
Reactions: Kingmudd
