P1000 PART #'s TO CONVERT 1000-3 TO 5 SEATER HELP!!
Tbowman053
Tbowman053
Henderson, MD
Guys has anyone converted their bed to a 5 seater from parts from factory I know guys have found used beds and swapped with each other but havent found anything close to that local. So im looking buying the parts from Honda. Apparently there is more to it then just a bed. I guess its got the base the bed, the seats, ect ect it goes on and on. Please help if you've done this or know someone along the east coast that wants a 3 seat bed.
Reactions: sharp
If you can’t find the parts in trade, it’s cheaper to trade the pioneer to a dealer for a 5 seater.
The frame itself is almost $800, the seat frames are $140 a piece, by the time you get all the fasteners, plastics, and seats you'll be way better off just trading the whole unit for a 5 seater.
pct
pct
Lost in the hills
790
1,023
Letart WV
I have a complete rear cage with all the belts and nets it is new when I got mine home from the dealer I removed it but I'm a ways from you
Reactions: CumminsPusher
SuperDutyJohn
SuperDutyJohn
254
436
Vero Beach, FL
Out of curiosity, why? If you want people in the back be forewarned: it sucks big time! It's a million degrees back there and the seats are substandard. Factor in the dust too, the larger roof is a backdraft for negative air to flow to the back seats.
P
Pstewart
0
Where do these accessories come from and how do I oder them, thanks
Dezrik
Dezrik
Follow me for adventure!
297
956
MOAB, Utahhhhhhhh
Just skip the awful rear 5 seater bed and just install a bench seat in your current 3 seater bed. Buy the "Foot" floorboard of the 5 Seater and cut and modify your bed so the passengers leg dangle. If you need to have a full bed, you can install a "3 seater bed liner" and some strategic placement of some removable supports you will have a full bed when you need it.
Reactions: TripleB
Dezrik
Dezrik
297
956
MOAB, Utahhhhhhhh
Here's some photos of this past wheeling seasons setup. Getting ready to reconfigure the bed 😁
20200313 175515 20200313 175534 20200313 175549 20200313 175543
Dezrik
Dezrik
297
956
MOAB, Utahhhhhhhh
Here's some photos from the build. The seat is a twisted x rear bench for a rzr 1000. After building the setup I found out the teryx4 had a option for a larger rear bench which would fill the bed a lot more. The rzr seat is fine for little butts but once they get bigger I imagine they will start complaining.
Do you have more pictures of how the seats are mounted? And what brand of seats are these?
20200304 211658 20200304 225701 20200304 215416 20200514 183223 20200304 235303 20200304 231720
Dezrik
Dezrik
297
956
MOAB, Utahhhhhhhh
Its a Honda you don't need to check the oil, but seriously I can just reach in there and check it no problem. If I'm doing a full service I remove the tire and just get it done. Sometimes I remove the bed, takes about 15 minutes.
I have got to ask, how in the sam hell do you check/change your oil?
Reactions: Haldog77
Haldog77
Haldog77
NTC's Mafia Enforcer
32,812
299,916
Bossier City, Louisiana
Ok. I have a hard time changing the air filter and checking oil and such with the bed up. I bet it would really be hard with it down.
