Pioneer 13 code
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
Can you upload a video to youtube?
Concentrate at least a minute on the dash while cranking/running/dying.
Did you confirm your wires are not crossed when you replaced the connectors?
I don't have a wiring diagram in front of me. Just make sure you didnt put the front ground on rear cyl etc.
Reactions: Buggyman and ChadD
Downeyd24
West Virginia
I did the harnesses one at a time so I wouldn’t get a wrong wire. I’m almost down to thinking it is the ECM
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
Do you own a service manual?
There is a 4 pin harness under the driver set. You can jump 2 wires i believe to clear the ECM.
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
Reactions: ChadD and Buggyman
67,170
Where did you get your injector harness from?
I bet the polarity is reversed.
Most of the amazon/eBay ones are.
Downeyd24
West Virginia
I bet the polarity is reversed. Most of the amazon/eBay ones are incorrect.
I’m honestly not sure. A friend of mine had them. I think I have the old one still around. I will compare. I honestly didn’t think to check that. I was too excited to hope that this would have me back up and having feed lol.
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
When you removed the factory connector.
How close did you cut it to the connector?
Maybe you still have a break in the wire?
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
I am at a loss for suggestions then.
Other than contaminated fuel. Which has happened in the past with other members.
It could be the ECM. Do you have anyone local with a same year machine to swap and try?
Downeyd24
West Virginia
I have two friends with them but not the same year.
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
What years do you have?
17 or newer might work.
Maybe get on the part fiche and see if the numbers change year to year. I know 16 is 16 only due to seatbelt interupt
