P500 Pioneer 1st Armored Division
196,252
Had something odd happen on the ride this time. I was going through the gears pretty quick and basically just slapped the shifter for 5th. It went into 5th, and I kept accelerating, but the dash just had a - where the number should be. Didn't think to try to up shift again to see if that worked but it went to 4 when I down shifted. Faked out the dash but not the trans?
Here's another pic from the ride too.
Gladwin
116,574
o_Oo_O:D:D
Maybe the kanutant valve was out of wack! I use a Langstrum 7" gangly wrench to adjust thato_O:D
Reactions: sharp and trigger
rocmar
rocmar
4,741
5,778
4 CORNERS
I've had the - on . Mine a few times...
but not driving...when I started...cause I start
..in 2nd...went from L ...to -.....
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
Those diamond plate accents are nice looking.
196,252
I'm getting that itch again to do something to this machine. I'm running out of ideas and accessories to put on this thing, cheap and easy ones anyway. Sent an email to SuperATV in regards to a discount on the EZ Steer eps, if they give me 10% off I'll order it. Still $540...DAMN!
Also just ordered Pro Armor 4 pt harnesses, didn't want to slip out of the seat crossing the Mackinaw Bridge. ;)
Amazon.com: Pro Armor Black 4-Point Harness with 2" Pads A114220: Automotive
116,574
Damn! That's steep! Hope they give u a discount! The pro armor you'll like. I could tell you liked it when we rode in mine. Good choice for the wife.
116,574
That's how I sold her on the idea, ' it's an issue of safety'! Power steering will be to aid in plowing. ;)
Roger that! Great minds think alike! :cool: Rhonda was skeptical at first but when she found out her 100lb frame sits still that was it! She won't go back.
196,252
I'll just have to wait until I get them to figure out where to attach the shoulder straps. 3 of the points could go to factory locations but the middle straps will have to be dealt with. I researched all of them out there and these looked the best built and they didn't seem suffocating on the rip ride. ;)
Reactions: sharp and Remington
116,574
You are right. The two bottom ones will go in the existing holes where the other 3 points went. The others however will be easy for you! They should strap to the bars right above your seat. There's are some threads on how to do it, but you can figure it out easy.
Reactions: sharp
196,252
Don't have bars in the middle by headrests in the 500, they go down at an angle. Might bolt the uppers together behind seat, make it a 3 pt.
Gotta have them in my hand to know for sure.
116,574
Ok my bad. If you look at my build, you'll see how I did mine. Sound like what your talking about. One things for sure, you won't regret doing it. :)
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
@JACKAL posted this from his build the other night on how he installed 4 points in his 500.
P500 - Jackal's P500
