F
Fishin_Chip
I am considering purchasing a P500 for plowing snow, or possibly a P700. I currently use a Grizzly 550 with a 60" Warn county style plow. I have 2km (1.25 mi) road plus some driveway/yard to keep clean. I like the county style plow because it throws the snow a bit further off of the road if you get a little speed up. I am thinking the UTV would add a little weight, maybe give me the capability to deal with a heavy snowfall a little better.
I would be equipping my machine with a 66" county plow (for the P500, probably a 72" if I end up with a P700). I would add a full cab and heater (Alumite for P500, possibly OEM for the P700)
So, I have a few questions for those of you currently using a comparable setup:
1. Will this be an upgrade for me?
2. Do you run OEM tires? I was thinking an 8 ply might stand up better. Any thoughts?
3. Probably end up with another Warn plow, although I will see if the Denali is an option locally. From what I can find here on the forums, both have their adherents. I welcome feedback here too.
4. Are there any other issues I should consider as I move forward?
Thanks in advance for your input.
Cheers!
Chip
Cheers!
Chip
