Pioneer 500 exhaust can anatomy
solrus
solrus
1,629
2,511
Montana
Worked on dissecting exhaust can.
Be09ece91ce3b50128f8d936994645739b3f33b71aa404cd24d3c92e0b3cbb1664e7c803a91bd72b7018d7b293915530Bd7ff577d6d4a4698e60cdbcaba68e308dd7b3bcfaaf345e52f7fbed508565e1210b3ea6e2369616d7685ff3657605b84274e07cca6a94f89dc5c5e3e54ce949B7445f55cfdc760a9bd4ad37709f77201fbd88ed4b529c73a399f438dec0e09dDdf5d2f39c753941df9e1f47df32d617Ee49611472231042a31b918fde357e62Bd790264f47b24400765b6677873b25c147ada53a1abc56669fa9add3a2e4dc12a36283cde4dc9f640c10b0402d9764a
Deleted member 3748
It doesn't look like that's going back together. Are you putting something else in its place?
Now that you have it apart, what are your thoughts about it?
Reactions: swsebek and solrus
solrus
solrus
1,629
2,511
Montana
Actually I put it back together and rewelded. Uploading video now. Now the question is to use it as it was in the same configuration or add super trap at the end or buy new Walker general purpose 2 inch inlet outlet exhaust . Catalytic converter will stay as it is. I opened it to about 1.75" , this should not restrict the flow. Opened can a bit also, not with 1.5" exhaust tip , it does not hick up anymore uphill. I feel that what I did did the trick. Now I want to reduce some noise if possible, seems like most of the noise comes just from the engine itself.
I've tried to add super trap exhaust and later rewedded old cap with 1.5" opening.
solrus
solrus
1,629
2,511
Montana
Do not recall, I posted somewhere db when I was doing another add on mod with walker exhaust. Let me search .
Video with super trap is on its way.
solrus
solrus
1,629
2,511
Montana
87 with super trap > 86 just OEM > 85 db with add on exhaust
but now I have super good flow , at least less restrictive then before, I'm sure Jack has even better flow with his straight pipe HMF exhaust , I wonder if he could measure db on his phone
160,066
Less restrictive is good, do you think it sounds any different?
Reactions: Dp5hunter
solrus
solrus
1,629
2,511
Montana
I might just take off super trap and use OEM cap and see how it will sound
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i hope your afr+ stays working mine just crapped out over the weekend so i have to wait until tuesday before i can call dobeck to figure whats going on!! the gauge no longer has back light and when i start the machine is jumps burried to the right and doesnt move and it runs the same as before i installed it
solrus
solrus
1,629
2,511
Montana
Crap. Hope it will be shipped soon.
I used it only 30 mins. Have not had a chance and was finishing my exhaust saga
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i hope its an easy fix if not i will not be happy ive had their ejks on a few machines for years with no problems now this only lasts 6 mths few hundred (never swamped) miles
solrus
solrus
1,629
2,511
Montana
Jak, can you measure noise with phone app? I'm curious how much noise reduction you have with your new HMF?
solrus
solrus
1,629
2,511
Montana
It's called sound meter on Google app store
Reactions: jak9922
