Recently had front differential case replaced under warranty due to a constant fluid leak. Now it seems like there is noticeable "clanging" noise from the front end. It sounds like something is loose and hitting the frame because I can feel it in the floor board. It doesn't do it all the time but mainly does it on rough terrain. If I grab both front axles at the same time, I can move them front to back slightly? Is this normal? I feel like this movement is what I'm hearing...
