Pioneer snorkel
Kcresci
Kcresci
16
9
Finally got around to installing the snorkel kit from snorkel your atv. I bought the snorkel cu I didn't feel like screwing around with all the pvc making it fit. The install was really easy and took a total of ten minutes. B2c9f15a47a694891b51deffa0e1602aC05f91370005e58759cbcb6799ee08b0
Reactions: sharp and Delton
266,541
Before you let @d_b goad you into entering submarine races, be sure and extend your fuel tank vent tube along with front & rear differential vent tubes if you haven't already. Nice looking snorkel though.
HondaTim
HondaTim
203
40
How do you like those silverback x lites?
Kcresci
Kcresci
16
9
Don't get me wrong the pull in the mud but if u have to ride on a slight amount of pavement it eats them right up. And they a really rough and make the whole bike rattle up until about 10mph
Kcresci
Kcresci
16
9
I'm gonna buy a set of zillas my buddy put a set on his ranger and he loves them they don't shake and they don't wear from pavement and still pull like a champ
d_b
d_b
302
240
See @JACKAL he's ready for submarine races, all vent lines included. No serious check diffs also.
H500driver
24
17
Palmetto, FL
Just received my kit from snorkelyouratv and the instructions are kinda hard to follow, can you provide a few more pictures on where it starts from the airbox and what was cut?
Kcresci
Kcresci
16
9
Not until tomorrow I cut mine right below where it 90's to the horizontal piece runs up to factory snorkel
Kcresci
Kcresci
16
9
Easiest way is to put all pieces together and hold it up to factory pipe before cutting
Hardwaterflyer
65
102
West Central Minnesota
Finished installing a "Snorkel Your ATV" kit on my P2-700 with a full Honda hard cab. Had to drill twice into the cab with a hole saw but that turned out good. Good instructions--I even painted the stainless hose clamps flat black to make the install less noticeable. Nice complete kit at a reasonable price. I think the engine breathes easier but I have no proof of that. I also replaced the Honda hose clamp that is next to the airbox with a wider 2" stainless clamp as the Honda clamp might be a weak point for the entire intake system. Took it out for a test drive and I think it is a bit faster on throttle response. I am using the intake tip that has a screen in it for now. The other tip provided without the screen might even make throttle response better yet but I will start with the screened version. I also am using the K&N air filter with the pre-filter screen.
Hardwaterflyer
65
102
Forgot to mention that I also cushioned the intake tube with a rubber hose where there is a bracket for the safety net which is no longer there. It is about shoulder high and should keep everything tighter and prevent vibration.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Hey guys... Considering buying this kit for my 700-4. Everyone satisfied with the product? Any complaints? Thanks!
Reactions: Tramguage1
