P500 Post your rear rack or box. Pics.
Mudder
Mudder
NTC/TAP Transition Member
11,855
90,272
L
Looks good! I'm getting close to spraying raptor bedliner on mine, did you primer the wood before you sprayed it?
Does spray bedliner end up rough and hard to clean dirt off versus a smooth finish?
JWard03
JWard03
54
153
North Carolina
You got a box with double duty as a rear bumper when backing up in the woods.
Yessir. I put a mat in the bottom tonight. I had been looking at industrial floor mats but didn't like anything I saw. Found these interlocking tiles at Lowes made of recycled tires for $30 and stapled them down to fit. I really like how it came out and it should be tougher than a floor mat.
IMG 2143 IMG 2142
211,660
View attachment 163907 View attachment 163908
Looks great!
Reactions: Mudder
Zaleski
Zaleski
67
176
Ohio
I had seen that one, wasn't sure if this was made by them or not.
I’m pretty sure I read in a post of his that it was, but i’m Sure they’ll chime in themselves
Solbergbbq
5
Mayacamas Mountains
Before buying my P5, the rack intrigued me as a platform to be creative. As seen in this thread, there are many different takes. I had some aluminum laying around and found a hardware store that sells fasteners by the lb! 1"square tube and 1/4"x20 grade 5 bolts of various lengths. The 48" wide setup has sides that measure to my dogs chest. Although I am done besides maybe adding some sort of gate; I do enjoy seeing all these setups!
20191007 184529
20191016 163650
Zaleski
Zaleski
67
176
Ohio
View attachment 165423 View attachment 165424
Great job, very unique too, ive never seen one like that, looks practical!
Mudder
Mudder
11,855
90,272
Looks nice @Solbergbbq , Customizing that flat rack to ones needs is the best. Glad it didn’t come with a limited size bed like the other models.
monaco
monaco
376
982
Indiana
bit.ly
I like that a whole lot. Looks very handy
Reactions: Dp5hunter
211,660
Butt! You dang flea! HA!
Reactions: Mudder
ShanethePain
ShanethePain
17
24
hanover, indiana
I'm curious with the rack and mods to the back how much each of them would weigh. I made mine out poplar 1" x 8" wood with proper u-bolt fasteners to the rack as well as wooden cleats to fasten each section to the lower wooden bottom, It weighs 26 lbs. It's very functional, but would like to lighten the weight requirement. I also do not want any squeeks, rattles, or noises coming from the rack/box. I do hunt and I get enough noise from the engine and other areas. I like the looks of the custom metal rigs but worry about the weight.
Mudder
Mudder
11,855
90,272
Agree, my first wooden box was so heavy, so changed to the aluminum cargo carrier, but also added a tool box with stuff, so back to heavy. But at least I now have emergency gear on rides. If not needing an enclosed box, the hitch cargo carriers are light and good for strapping things in, and padded for no squeeks.
0587274D 1BD0 45A6 B543 34DEB450AD57
RumpRocket
189
295
USA
I went with the same setup you have and love it....thanks for the inspiration.
RobertMac
RobertMac
10
20
NC
Spent the past couple days cutting this apart and putting back together. cut 6" off the front of a cargo carrier and made it 1" narrower to match up with box width. Fastened the two together and added fire extinguisher with bracket. I also have a metal jerry can on order for the other side.
Pioneer Rack Pioneer rack 3 Pioneer rack 2
