P1000 Pre load tool for fox shocks?
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Dose anyone no where I can order the pre load tool for fox shocks can’t seem to find it
Dirtstiffs-1000
Dirtstiffs-1000
1,655
6,029
hondasxs.com
208,725
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
I have found that when the machine is up on stands and at full droop, you can turn the whole spring and the ring right along with it quite easily.
A set of mechanics gloves works well.
A lot easier than dealing with those clunky spanner wrenches.
Jankyeye
Jankyeye
829
4,007
Tampa, Fl.
I was able to get about 1.5” of preload on the front by spinning the spring. I could not get the rear to cooperate though.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Awesome thanks I will try this method I ran my front down a lot a few weeks ago but my buddy had a good wrench now I gotta level buggy bring rear down some and maybe release some on front the pics are soon to come
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
@sdelam did remind me that (at least with the stock springs) the rear adjusters get really hard to turn after that upper coil spring compresses.
I do remember it got a lot easier with single rate springs, but now I'm not 100% sure I was able to do them by hand either...
Reactions: Squeegee
MX4life320
MX4life320
14
Illinois
How high is everyone setting their preload? I am getting a lot of sag on mine, but Ive never adjusted it either. Only a 10-15 threads on the front, I didn't check the rear though.
TIA
115,290
TIA
Thats a loaded question. Everyone is very very different to there riding style, types of springs, tires etc.
If I told u what mine is and you do that, you wouldn't be happy!
You just have to try multiple adjustments to see what works for you. Sorry
Scoop
Scoop
5,130
20,278
  3. Talon R LV
Just did this on all four about 2 weeks ago. I was only able to add preload (all four corners) for a few turns before I realized it would be far easier to remove them, put them in a vice, and adjust there. I even had a legit spanner tool for the job.
I can post my measurements (already did somewhere), but as others already said, everybody likes theirs set differently. I do NOT have a lift, but wanted to clear a 5 gallon bucket front to back. That meant a little more preload than most.
Scoop
Scoop
5,130
20,278
  3. Talon R LV
I used calipers and measured from the point where the shock body thread met the housing (upper arrow) to the top of the LOWER preload adjustment collar (bottom arrow). I'll have to double-check my numbers (written down out in the pole barn), but I believe they were:
Fronts: 46.75 MM
Rear: 44.5 MM
Again, I was pretty aggressive to get the clearance I wanted, and I don't think I've got too much preload set ATM. Guess I'll soon find out at TO in another two weeks ... :p
IIRC, I was able to spin the springs by hand on the fronts, but for the rears, I did have to use the spanner wrench. Even with the wrench, there was no way I was adjusting this preload without the cushions being off the machine and in my vice. If you can adjust yours without removal, my hat is off to you.
1684423176470
NewHere2
NewHere2
Village Idiot In Training
41,602
343,332
High Plains of SD
Pro Tip : When changing springs, after reassembling the shock; set your preload height (rough-in measurement, ya gotta start somewhere) before releasing the pressure on the spring.
