Question on Simple Jack
TxDoc
TxDoc
1,648
5,728
TEXAS 🇨🇱
photos.app.goo.gl
I've have Honda ATVs since 1997 and a 2004 Yamaha Rhino.
A long time ago, I ran Slime in my tires.
I don't any longer as the Pioneer will go so fast and I don't want since kind of induced imbalance causing since kind of vibration and instability, or some other problem.
I carry these, now, as they are reinforced and cure to the tire material and are waterproof.
TECH Permacure Tire Repair Kit - The Ideal Size Tire Repairs and Tools for Passenger Cars, Light Trucks, SUVs, Trailers, ATVs, Golf Carts, Farm Equipment and More (8 Repairs) https://www.amazon.com/dp/B01LFSVPNG?tag=sxsweb24-20
I'll probably jinx myself....
I've never had a flat. But, I want an "out" and not be trapped in a corner.
I am looking for a basic, small, jack that I can operate with one hand, as I can't use my left hand due to a stroke.
I've even looked at these bags that use your exhaust from the tail pipe for trucks, but smaller. But, they cost a lot and take up a lot of room
Seems like people in here have either figured out the best solution or know someone who did, and might have a suggestion.
I don't do rock crawling or neck deep mud riding. I'm mostly on dirt roads and trails, pavement, and hay fields.
Maybe a simple HF bottle jack and a square piece is scrap aluminum as a foot? I don't know.
Thanks for any ideas or suggestions.
I carry an 18 volt Milwaukee tools impact wrench and socket to change a tire and a backup simple hand tool if the battery tool happens to fail
WagginTail
WagginTail
1,474
5,459
SC
Try out a scissor jack from the trunk of your car. You can use the cordless impact to raise and lower it. And they are small
That's what I was going to suggest. I have this one but haven't needed to use it yet. I welded a nut on it to be able to use my impact. I'm sure there are other brands with a nut already on it.
BIG RED T10152 Torin Steel Scissor Lift Jack Car Kit, 1.5 Ton (3,000 lb) Capacity, Red https://www.amazon.com/dp/B004PX8BC2?tag=sxsweb24-20
157,983
I carry a bottle jack in a case under the drivers seat in my rig. Never had to use it yet.
Battery and jack
Couldn't help but think of this though...
Simple jack thumb 1200w
Robobrainiac
Robobrainiac
2,460
8,578
I would recommend the scissor jack or bottle jack as mentioned above.
My choice if I were in your situation would be the scissor jack with cordless impact to raise and lift. The scissor jack is lighter and easier to maneuver. It also has a taller lift capability.
If I can add to your repair kit.....
Colby externally installation capable valve stems.
Sidewall slug from our club store.
If you are comfortable with it. A tire seating fire fluid. I personally use brake clean. I have been a mechanic now for 16 years. I prefer brake clean for it's multi use capability. I use a stick lighter to keep my hands away. A little goes a long way.
Here is an example if you have ever been curious of the process.
Jerryg
Jerryg
10,725
86,678
NEPA
I prefer the rope and screwdriver method.
Or you can use a ratchet strap.
ODAMO
ODAMO
1,177
3,206
Nothin like the smell of burning phosgene gas in the morning.
Bighat
Bighat
874
3,734
Gallipolis Ohio
I don't carry one because I can walk back to the house or hitch a ride where I'm at but if I went on the trails the scissor jack would be my choice. You can take to one out of your truck or get one at the junkyard. But if you forget the jack you can use a log to drive up on and raise your tire off the ground. How to Change a Tire on the Trail
TxDoc
TxDoc
1,648
5,728
TEXAS 🇨🇱
photos.app.goo.gl
Thank you for all the information, suggestions and help.
I bought a HF scissor jack and one of their canvas till bags to keep the jack and accessories like tire plugs, inside.
I also bought one of these too use with the electric drill..
TONDA Scissor Jack Adapter for 1/2 Inch Impact Wrench or 13/16 Inch Lug Wrench, Scissor Jack Drill Adapter for Impact Drills Socket Automotive Jack RV Trailer Leveling Jack https://www.amazon.com/dp/B0793PJBB6?tag=sxsweb24-20
Thank you, an again.
Jerryg
Jerryg
10,725
86,678
NEPA
If anyone is interested, it's a bit less expensive here.
WagginTail
WagginTail
1,474
5,459
SC
Yea gotta watch Amazon and their prices. It'll be one price today and different tomorrow
Dirtstiffs-1000
Dirtstiffs-1000
1,560
5,685
hondasxs.com
I just ordered one to replace my heavy duty Farm(sheep herder's) jack, I seldom use.
Figured I'd shed some weight and create space.
I looked at several models of car jacks, but price and jack surface cap configurations, pushed me off the fence to order a Tusk and move on.
The Tusk is 2 Ton rated.
Tusk will expand - raise 18", whereas many of the others only raise 15" or less.
I bought it with the roll bar mount.
Reasonable reviews.
Cheaper through Rock Mtn Atv.
I'll give it a test run Saturday, when it arrives.
5,047
22,620
